| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#169 |
Drives: LR BRZ Ltd, 06 STi
added oil change number 4. Looks like the values have planed out and the stock oil is still doing well.
#170 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
#172 |
fixed, I had linked trying to use google+ which was weaksauce. Switched back to picasa.
Thanks! added to the first post list, what oil are you using? |
#173 |
Drives: Frs
I have been using the free dealer oil changes.
#174 | |
Drives: 2004 Subaru Forester 2.5XT
What air and oil filters are you using? Hopefully the silicon is still from break-in because it typically drops a little more quickly. -Dennis |
#175 | |
I still have the original air filter in which is made by Toyota. I checked it a few times and knocked out a couple bugs but it's still white. It looks like an industrial HEPA filter compared to most stock ones! I'm using the Subaru stock oil filter which is the black wide one by Tokyo roki. |
#176 |
Drives: Frs
I also had the third fill from the dealer ... I guess we will find out
I'm at 19k miles now, and plan on using my third free change at 22.5k miles Then I will need to decide what oil to use after Original air filter and oem Subaru black oil filter since new |
#177 |
RL - You're doing your own oil changes, right? Note the difference in viscosity with Jeff's uoa. 9.3 cst's @ 100C is where a 30 weight begins. Some oils do thin out with use and then thicken back up again and could be what happened here. This is something noticeable if you do several uoa's on the same oil over the entire interval.
I would probably try to keep the intervals at just under 7,500 miles, despite what Blackstone says. -Dennis |
#178 | |
#179 |
Drives: Ion Redline
I was pretty dead set on using Sustina for my first change, but I'm leaning more and more towards just using the Subie Idemitsu, especially after seeing some of these UOAs. I still think the Eneos is top notch, but being as my driving habits are somewhat on the "reserved" side, and that I plan on 5K drains, I might as well save the $30 while still keeping a great quality fill.
"Bullshit, asshole! No one likes the tuna here!"
#180 | |
#181 |
How much does the factory fill run on the regular anyway? Maybe I'll give it a try. Might as well try different oils and see what I like.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#182 |
Drives: Subaru BRZ Silver 6MT
Guys, I've never changed my oil before, and my car just hit 7500. Changing it will be easy enough, but what oil/filter do I buy? I live in VA
| DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
| First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
| When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
| Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 76 | 04-15-2012 04:44 AM |
