Old 04-23-2013, 09:20 PM   #169
R L Newb
Drives: LR BRZ Ltd, 06 STi
added oil change number 4. Looks like the values have planed out and the stock oil is still doing well.
R L Newb is offline   Reply With Quote
Old 04-24-2013, 11:33 AM   #170
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Its really small, can you post a larger resolution?
Ranatsu is offline   Reply With Quote
Old 04-24-2013, 11:55 AM   #171
Jeffsu350
Drives: Frs
here is my second oil change
Jeffsu350 is offline   Reply With Quote
The Following User Says Thank You to Jeffsu350 For This Useful Post:
R L Newb (04-24-2013)
Old 04-24-2013, 12:48 PM   #172
R L Newb
fixed, I had linked trying to use google+ which was weaksauce. Switched back to picasa.
Thanks! added to the first post list, what oil are you using?
Old 04-24-2013, 01:00 PM   #173
Jeffsu350
Drives: Frs
I have been using the free dealer oil changes.
Old 04-24-2013, 01:09 PM   #174
bluesubie
Drives: 2004 Subaru Forester 2.5XT
The oil is thickened up to a 30 weight so I wonder if you have some oxidation going on. This is why I like Oil Analyzer's Inc because you get TBN, oxidation, and nitration cheaper than a Blackstone uoa without TBN.
What air and oil filters are you using? Hopefully the silicon is still from break-in because it typically drops a little more quickly.
-Dennis
bluesubie is offline   Reply With Quote
Old 04-24-2013, 01:24 PM   #175
R L Newb
-Dennis
I can try sending the next sample out to those guys and see. Not sure what's up with the oil weight. It should be the same formula as the 3rd report and about the same miles. The only difference is I took the sample cold this time.
I still have the original air filter in which is made by Toyota. I checked it a few times and knocked out a couple bugs but it's still white. It looks like an industrial HEPA filter compared to most stock ones! I'm using the Subaru stock oil filter which is the black wide one by Tokyo roki.
Old 04-24-2013, 01:44 PM   #176
Jeffsu350
Drives: Frs
I also had the third fill from the dealer ... I guess we will find out
I'm at 19k miles now, and plan on using my third free change at 22.5k miles
Then I will need to decide what oil to use after
Original air filter and oem Subaru black oil filter since new
Old 04-24-2013, 02:37 PM   #177
bluesubie
RL - You're doing your own oil changes, right? Note the difference in viscosity with Jeff's uoa. 9.3 cst's @ 100C is where a 30 weight begins. Some oils do thin out with use and then thicken back up again and could be what happened here. This is something noticeable if you do several uoa's on the same oil over the entire interval.
I would probably try to keep the intervals at just under 7,500 miles, despite what Blackstone says.
-Dennis
Old 04-24-2013, 03:03 PM   #178
R L Newb
-Dennis
Yeah I'm doing my own with the Subie 0w-20. It looks like this latest one is the only I've had with the spike in viscosity. We'll see how this round goes.
Old 04-24-2013, 05:12 PM   #179
KSC
KSC's Avatar
Drives: Ion Redline
I was pretty dead set on using Sustina for my first change, but I'm leaning more and more towards just using the Subie Idemitsu, especially after seeing some of these UOAs. I still think the Eneos is top notch, but being as my driving habits are somewhat on the "reserved" side, and that I plan on 5K drains, I might as well save the $30 while still keeping a great quality fill.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 05-01-2013, 05:05 PM   #180
R L Newb
30k miles and still going strong on the stock oil. Maybe if you were tracking the car a more robust oil would be in order but it seems like the stock oil holds up without any problems, especially at that change interval.
Old 05-01-2013, 05:51 PM   #181
zoomzoomers
zoomzoomers's Avatar
How much does the factory fill run on the regular anyway? Maybe I'll give it a try. Might as well try different oils and see what I like.
Old 05-01-2013, 06:01 PM   #182
CheesusCrust
Drives: Subaru BRZ Silver 6MT
Guys, I've never changed my oil before, and my car just hit 7500. Changing it will be easy enough, but what oil/filter do I buy? I live in VA
CheesusCrust is offline   Reply With Quote
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
