Old 04-12-2013, 04:35 PM   #85
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
What sold me on this intake was the increased air volume and straighter intake track.
Can you get any straighter than the FA20 or AMR CAI?
Can you get more air volume than Perrin, FA20 or AMR?
Intake Air Temperature has to be higher if the airbox/filter is in the engine compartment
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-12-2013, 04:44 PM   #86
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I think he meant the path from the air filter to the throttle body is straight, because perrin, FA20, AMR all have huge long tubes with lots of bends.
shu5892001 is offline   Reply With Quote
The Following User Says Thank You to shu5892001 For This Useful Post:
tripjammer (04-12-2013)
Old 04-12-2013, 04:53 PM   #87
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Yep, that is what I was talking about. I am not hating on those other intakes.
tripjammer is offline   Reply With Quote
Old 04-12-2013, 06:29 PM   #88
BAS
Drives: Snow White
The throttle response is improved significantly. I am by no means claiming to be an expert and engine/exhaust modifications wise I am only running TRD CAI and TRD exhaust. Was running the exhaust by itself since day 1, so I never had a comparison. After installing the CAI, noticeably better response on the throttle input.
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
The Following User Says Thank You to BAS For This Useful Post:
DAEMANO (06-18-2013)
Old 04-12-2013, 06:34 PM   #89
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I can see response increasing for sure and that alone is a plus to me considering I have found most aftermarkets give you a bit of a lag
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr.Jay For This Useful Post:
Fred Flintstone (04-10-2016), tripjammer (04-13-2013)
Old 04-12-2013, 06:50 PM   #90
NickFRS
Drives: 2013 Asphalt FRS
BTW if anyone is near the PDX area Dyno pulls are only $25 bucks at PREracing in portland OR atm.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
funwheeldrive (08-04-2014)
Old 04-13-2013, 01:40 AM   #91
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Same here.
Old 04-13-2013, 02:17 AM   #92
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Originally Posted by iketiak View Post
I wonder if this would help the TRD CAI even more...
Nice, reminds me of the spoon & J's racing snorkels for the S2k! This should do better than the stock snorkels.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 04-13-2013, 07:10 AM   #93
FR-S Matt
Not the true cold air intakes. Should see the thread where the guy modified his Injen intake into a full CAI and eliminated the bogging down and rough idle with 3 1/2 piping.
Old 04-13-2013, 07:47 AM   #94
2forme
Yea but he also had to remove the radiator shroud in the process. That will affect the efficiency of the radiator for sure.
The Following 5 Users Say Thank You to 2forme For This Useful Post:
Cessblood (04-14-2013), Hanakuso (04-14-2013), mad_sb (04-13-2013), Mr.Jay (04-13-2013), tripjammer (04-13-2013)
Old 04-13-2013, 09:33 AM   #95
roddy
roddy's Avatar
Drives: '13 Ultramarine
My dealer just called...intake is in!
Old 04-13-2013, 11:11 AM   #96
mad_sb
Drives: 2013 Asphalt FR-S
THANK YOU! i have been waiting for someone to mention that with all these people and companies removing that shroud for CAI's, turbo kits, etc etc...
The Following 3 Users Say Thank You to mad_sb For This Useful Post:
2forme (04-13-2013), Cessblood (04-14-2013), tripjammer (04-13-2013)
Old 04-13-2013, 12:55 PM   #97
Red2Liter
Drives: Subaru BRZ Limited, Red
210 HP
Originally Posted by SkullWorks View Post
the 210 HP claim is weird, they either used some hokey pokey conversion from a chassis Dyno, (don't care who's or what...conversion rates are a best guess...at best) or this is a number passed down from the Celeb race crew...I don't believe anything without data. I would be interested in seeing a back to back between the stock and celeb race cars.
I have a friend who is fond of stating: "A man without data has nothing but an opinion and his D!@% in his hand"
I have no reason to believe this isn't the best intake on the market, there appears to be a nice volute heading into the MAF tube, a nice big "plenum" of sorts and as much or more cold air as any of the aftermarket options. all with less restriction, and since TRD has all the engine data it is much easier for them to determine the correct volume box to make the motor happy.
I predict that the Intake won't make the best peak number but I am Certain it will produce the best average numbers, you'd be amazed what an OEM can do with airflow calculations.
I think the man said,: "it adds 8 to 11 HP. call it 10." I don't think he mentioned a total HP. The car is nominally a 200 HP engine, though we all know that's not at the rear wheels.
Red2Liter is offline   Reply With Quote
Old 04-13-2013, 01:48 PM   #98
2forme
Yea, with the paper thin radiator this car has, it needs all the help it can get.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
