Old 04-10-2013, 04:48 PM   #1
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
TRD Intake ! CAI ?!
Personally, I have tried out the INJEN and AFE intake on the BRZ / FRS. Both does have pretty good high rpm power gains which you can feel it but when it comes to ON/OFF throttle response, I think stock air box performs much better. With the stock intake or with a panel filter, the acceleration improves at lower rpm especially 1-4k range but you won't have the pull like the after market intakes.
The first time I saw the TRD intake on the Scion celebrity race car, that design really get my attention. Bigger air box increasing intake volume, this intake will improve throttle response and power. I don't think it will make as much power as a aftermarket box up cone filter, however, throttle response SHOULD be unbeatable.
Since no one has dyno the TRD intake, it's too early to judge if it's good or bad. So I will be dynoing this unit and plus a DRIFT OFFICE tune along with it.
Here's are some pics for the intake :
I will keep you update how the install and dyno goes.
Thanks
Ben
AJ PwR is offline   Reply With Quote
The Following 18 Users Say Thank You to AJ PwR For This Useful Post:
acro (04-10-2013), Anthonytpt (04-10-2013), Bonburner (04-10-2013), Craig (04-10-2013), Drift-Office (04-10-2013), Fly Guy (04-13-2013), Hanakuso (04-10-2013), humanshield (04-27-2013), industrial (04-10-2013), Jeff86 (04-19-2013), JETRED (04-18-2013), Nambo (04-10-2013), NWFRS (08-01-2014), OnkelC (04-10-2013), shu5892001 (04-10-2013), thorlius (04-15-2013), tripjammer (04-11-2013), zoomzoomers (04-11-2013)
Old 04-10-2013, 05:00 PM   #2
NickFRS
Drives: 2013 Asphalt FRS
Take a picture of the inside of the box~~~
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-10-2013, 05:06 PM   #3
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Thanks a lot of doing all of this, exactly what we need to see. Dyno for stock and tuned!
shu5892001 is offline   Reply With Quote
Old 04-10-2013, 05:11 PM   #4
Hanakuso
In that second picture, it almost looks like you can take off the red TRD letters. I'd like to do that if it's possible.
Hanakuso is offline   Reply With Quote
Old 04-10-2013, 05:13 PM   #5
OrbitalEllipses
Drives: Attitude
@F1point4 has a picture from the inside of the box. It appears you can push them out or shave them.
Old 04-10-2013, 05:20 PM   #6
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
20130403-86TRDIntake-033 by VictorN07, on Flickr
The rest of my pictures are on my flickr
F1point4 is offline   Reply With Quote
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
Hanakuso (04-10-2013), melon (02-25-2014)
Old 04-10-2013, 05:22 PM   #7
FR-S Matt
In for the depressing results. Glad someone is finally doing it so I can either STFU or continue my bashing.
The Following 4 Users Say Thank You to FR-S Matt For This Useful Post:
Calum (04-10-2013), jumbaco (04-19-2013), MagicBobert (04-28-2014), naikaidriver (04-10-2013)
Old 04-10-2013, 05:26 PM   #8
AJ PwR
AJ PwR's Avatar
You can take them off but I think there will be holes. Just take peek my pics below !
The Following 3 Users Say Thank You to AJ PwR For This Useful Post:
Bonburner (04-10-2013), Hanakuso (04-10-2013), tripjammer (04-11-2013)
Old 04-10-2013, 05:29 PM   #9
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
in for results, i like the look
Jesse is offline   Reply With Quote
Old 04-10-2013, 05:30 PM   #10
shu5892001
Ontario's FT86
I wonder if it's possible to make the opening larger and pair it up with a bigger air duct
Old 04-10-2013, 05:31 PM   #11
Hanakuso
Thanks. I saw your post and noticed you were surprised by it being made in the US. TRD USA and TRD Japan are totally different. Iirc, TRD USA is actually under Toyota North America and has nothing to do with Toyota Japan. Many of the exhaust are rebranded or made by US companies.
Old 04-10-2013, 05:32 PM   #12
ST185RC
Drives: White Out FR-S
Why would you go take off 50% of the products value?
ST185RC is offline   Reply With Quote
Old 04-10-2013, 05:38 PM   #13
Hanakuso
IMO it would look completely stock with it off.
You could probably add this on, but the actual opening to the intake can't be changed most likely, unless you mod it.
http://jprova.co.jp/products/intake/...000001o5j.html
Old 04-10-2013, 05:39 PM   #14
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
what is the length and width of the filter to calculate area and compare to the OEM one.
Mars2 is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
