Old 03-21-2013, 02:13 PM   #211
dabocx
dabocx's Avatar
Drives: Scion FRS
Can you do a before and after dyno?
Im hoping to jump on this or avo soon, houston is a 5 hour drive away but its going to be worth it. Just wish i could get a drive in one first.
dabocx is offline   Reply With Quote
Old 03-22-2013, 09:13 AM   #212
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
We'll show the comparison. Since we'll probably be sending back the units before receiving the new ones (unless someone does a core charge), there will most likely not be a right before the new unit dyno. All of ours are SAE corrected so results should be pretty accurate.
We can scratch the alternator tilt bracket from the list.
The silver portion shows the area that is different.
These were sent overnight from Vortech.
Sent from my SCH-I605 using Tapatalk 2
PhastekSport is offline   Reply With Quote
Old 03-22-2013, 10:16 AM   #213
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
so, just for the record, not wanting to pollute or start controversy, but just want to clarify:
10psi on the 'old' stage1 impeller/compressor at 10psi is NOT The same as 10psi on the new stage2 compressor/impeller
the older design was built to offer overboost protection, and runs outta breath at 9psi+
the 10psi kit I'm on with Perrins tune will be dyno'd by me Tuesday coming, and the curves look very different, as do the boost plots, so everything before 7500 rpms and before 9/10 psi looks way different on those charts too
Originally Posted by 2forme View Post
Visconti had already posted somewhere that the 10psi kit doesn't make much more than the 7psi kit on pump gas. From the look of that curve, it's pulling something up top because ECU doesn't like what it's seeing. Look at the smoothness of the base dynos in comparison.
I do not think John Visconti has thge same kit as me or Jeff, tho I am sure that will change in time
There is a huge difference between 7psi and 10psi on my vortech kit-while I cant comment on absolute peak power without dynos, every psi DOES matter
Huehuecoyotl is offline   Reply With Quote
Old 03-22-2013, 10:21 AM   #214
2forme
I think you should double check that before posting .
Old 03-22-2013, 10:26 AM   #215
Huehuecoyotl
Well, I hope he is having as much fun with this kit past 10psi as I am..(next weeks testing! Cant wait!)
Old 03-22-2013, 11:03 AM   #216
PhastekSport
Keep on doing the leg work so when we get the new compressor the tune will be perfect :-).
Old 03-22-2013, 11:07 AM   #217
Huehuecoyotl
One thing we ALL agree on is this kit is silly sweet. Wait till you start to giggle while you drive it at like all rpms...
Old 03-23-2013, 01:24 AM   #218
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
It's Here
Is this the first Vortech kit with a header?
Thanks Jeremy at @FT-86 SpeedFactory for the awesome as always service.
20130322-BorlaHeaderTeaser-047 by VictorN07, on Flickr
20130322-BorlaHeaderTeaser-048 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 03-23-2013, 01:13 PM   #219
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by F1point4 View Post
It's Here
Quick Q, will this header make the boxer burble more pronounced? I mean cuz it seems to be WAY UEL... I kinda miss it on the BRZ.
Adeets is offline   Reply With Quote
Old 03-23-2013, 01:57 PM   #220
Opposed
Drives: 2013 Asphalt FR-S
Yes it will. Have you not seen the videos? [ame="http://www.youtube.com/watch?v=nrJ_CTdHANo"]Borla UEL Header for the Scion FRS and Subaru BRZ - In Car - YouTube[/ame]
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 03-23-2013, 03:19 PM   #221
Adeets
OEDC
Adeets's Avatar
Why no i have not, thank you.
Old 03-23-2013, 03:58 PM   #222
Opposed
Sounds pretty B.A. huh?
Old 03-23-2013, 05:09 PM   #223
Adeets
OEDC
Adeets's Avatar
Just listened to it in the office, it's exactly what I want... Lemme guess no cat though... Think I could pass emissions with it?
Was stuck on the floor most of the day, got called in because the robots were trying to throw cases at the operators... Apparently they hate the operators as much as I do.
Old 03-23-2013, 05:18 PM   #224
Opposed
Was stuck on the floor most of the day, got called in because the robots were trying to throw cases at the operators... Apart entry they hate the operators as much as I do.
Sorry man, no cats for the Bolra's from what I remember. I don't know about passing the emissions part. Maybe if you kept the cat in the front pipe???
ft86, perrin, phastek, supercharger, vortech
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-15-2013 11:48 PM
