Old 02-06-2013, 11:33 PM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by caliboy15 View Post
stock shocks and aftermarket springs is a no no
Errr...not always true
Fizz is offline   Reply With Quote
The Following 2 Users Say Thank You to Fizz For This Useful Post:
chadstyle (02-06-2013), Juvenile (02-14-2013)
Old 02-07-2013, 12:00 AM   #16
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Running Eibach sportlines on stock struts and they handle amazing. Its all in the install. These struts work well a little deeper in the stroke.
chadstyle is offline   Reply With Quote
Old 02-07-2013, 12:11 AM   #17
whataboutbob
AutoX-10/10ths every run
RCEs on stock struts, no problem here. Didn't use an impact at any point of the dis-assembly or assembly process. I ended up using a t-handle allen and a spark plug tool with a open ended wrench that fit the spark plug tool.
Build thread:Here
Old 02-07-2013, 12:55 AM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Basically all lowering springs are designed for OEM dampers.
Sure, OEM dampers with 80k may not like the increased rates, but new dampers (all of these cars currently) will be just fine.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-07-2013, 02:45 AM   #19
caliboy15
caliboy15's Avatar
Drives: 1994 NA8
It may work, but not gonna last long as oem springs/shocks combo.
caliboy15 is offline   Reply With Quote
Old 02-07-2013, 07:48 AM   #20
Turn in Concepts
Turn in Concepts's Avatar
I've seen it before and typically on springs like the Sportlines that lower a car a large amount.
As for using and impact for installation, as long as the shaft is held there should be no issues.
Tony
Turn in Concepts is offline   Reply With Quote
Old 02-07-2013, 08:46 AM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd agree with that but that's like saying don't track your car because wheel bearings won't last as long.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Jackson (02-07-2013)
Old 02-07-2013, 08:48 AM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tony
Most people don't hold the shaft and just impact it on, especially guys working out of their home garage.
I ran the sportlines for thousands of miles and my dampers are still just fine. I'd have no problem running them for tens of thousands if only Sebring's Turn 1 and 17 were smoother.. need higher rates to lower the car at all to avoid bumpstops
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 07:24 PM   #23
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Brought it to the garage last night and the other strut was leaking.. so both my rears are done and need to be replaced.. going back to stock height in the meantime until I get coilovers..
Hopefully my front ones don't go before putting the stock springs back on..
01s0uljah is offline   Reply With Quote
Old 02-14-2013, 12:54 PM   #24
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
It's your shocks you need to replace, not the Sportline springs. The shocks were damaged during installation causing the clunking and leaking.
If you used an impact gun during the installation I'm 99.9% sure the internals of the shock came disassembled. There are quite a few people this has happened to.
Jackson is offline   Reply With Quote
Old 02-14-2013, 02:09 PM   #25
wparsons
wparsons's Avatar
Most shock manufacturers suggest replacing them around every 50k miles (80k km's), they'll easily last that long on sane lowering springs (ie not a 3" drop with stupidly high rates). Might not last as long as stock, but that's the same as stickier tires, oil, gas, etc when driving a car hard.
flickr
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 48 06-07-2013 02:19 PM
Debating between Sportlines or STANCE coils.. wWaldo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 01-23-2013 11:14 AM
eibach sportlines clunking.. frsguy707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-24-2012 11:42 AM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
