Drives: Asphalt Frs
Debating between Sportlines or STANCE coils..
So I haven't gotten my FRS yet so I figured i'd do some shopping before I actually get the car
![]() So my previous car was a Stage 2 2010 Genesis coupe. The suspension was Eibach Sportlines, I like it, I didn't mind the harsh ride but from what I remember I wanted lower. Now for the FRS i'll be running 18x8.5 +35 & 18x9.5 +40 , I THINK the sportlines will be perfect but i'm scared they wont be and thinking i should get STANCE coils. But now my question is if i'm getting these coils, I have to rebuild them every 4 years? where as Sportlines there pretty much good, my shocks might blow but then I could replace them with Koni Shocks? Do I have to get Control arms with the coils or the springs? Not much of an expert in the suspension domain. Which is why I ask. |
Drives: DC5
Id say coilovers, but depending on what you intend to do with the car along with your budget. Koni yellows paired with swift lowering springs are magic and better performing than nearly any lower to some mid end coilovers out there. Ive read good things about the RCE yellow springs as well so i guess those might be a decent option too. But as far as i recall, rce doesnt actually manufacture their own springs so thats the only thing that bothers me. Cant say much about eibach as i think their lowering springs are total crap.
#3 | |
Drives: Asphalt Frs
#4 | |
ill roller has a thread on the Stance coils and he is a fan. We have them in stock too ![]() Here is his review thread. http://www.ft86club.com/forums/showthread.php?t=23994 New control arms are recommended in the rear because you will need to adjust your camber after lowering the car. You won't need them in the front because you'll have camber plates for the adjustment. Hope this helps a little, -Yo |
#5 | |
Drives: Asphalt Frs
Any news on HSD coils I believe there the same price. . Control arms in the rear are they easy to install |
Drives: Whiteout FR-S
Rear control arms are easy to install, depending on which ones you get though they may not be easy adjust.
Drives: Asphalt Frs
If i go with some HSD the only other thing I would need are teh Rear Control Arms?
i'm aiming for a slammed FRS |
You could get control arms or the Whiteline camber bushings, you might want to check on some adjustable sway bar end links if you are going really low. A lot of us here shake our heads when we see the desire to slam the car so be prepared for it.
Drives: Asphalt Frs
It's alright, would I need control arms with sportlines? I don't feel like paying over 2000$ on suspension.
#10 | |
Drives: Pegasus White 86GTS
Pegasus White 6MT got it. :happy0180:
#11 |
You will most likely need some kind of camber correction with the Sportlines but still would come out better off in my opinion.
Sportlines ~250 SPC LCA ~300 Koni's if/when the stock ones need replaced ~770 $1320 total but no adjustability. If you want adjustability and to get low for now i would go this route http://www.ground-control-store.com/...ion.php?II=938 and you can put Koni's or Bilstein's in later if neccessary. http://www.ground-control-store.com/...ion.php?II=930 |
#12 | |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I was going the cheap coil over, but after speaking to a couple suspension guys, I'm getting coils now and KW's later when it's in my budget |
#13 |
Drives: 2013 Whiteout FRS
If you're looking to go low and slow, I think you'll find that the Sportlines dont go low enough. I had Stance on my S14 a few years back and was satisfied with them. I got coils to lower the car for a bit now and I'm planning to get KWs later.
Check the link for Sportline vs stock height pics http://www.ft86club.com/forums/showt...602#post655602
#14 | |
Drives: Asphalt Frs
i'm looking for a 2" drop about, that should be perfect. Whats the difference between KSport and Tein Basis Coilovers? Tein basis Coilovers seem great on paper and what i need.. I don't need high end suspension. What about Ksport? Just watched the review seem to be best bang for your buck? |
| eibach sportlines clunking.. | frsguy707 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 10-24-2012 11:42 AM |
| Debating on wheels . which spacers? | Mrqb22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-04-2012 09:28 PM |
| Debating...Now or later? | IndyBRZ | BRZ First-Gen (2012+) — General Topics | 9 | 09-26-2012 10:32 PM |
| Eibach Sportlines Finally Available! | PRO Import Tuners | Brakes, Suspension, Chassis | 1 | 08-22-2012 07:42 PM |
