Old 02-02-2013, 07:07 PM   #1
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Eibach Sportlines on the BRZ - Blown Strut
Decided to lower the BRZ this weekend with the Eibach Sportlines and had them installed at a buddy's shop. After getting them installed, i noticed stiffness in my rear left and a clunking noise after each bump.. Brought it back and determined it was a blown strut right away..
Noticed there was a few guys on here that blew their struts after installing these springs but after a few thousand but not immediately.
Anyone else blow them right after installation?
01s0uljah is offline   Reply With Quote
Old 02-02-2013, 07:36 PM   #2
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
Did the bump stops get installed? I'm curious because this is the lowering route I was going to go with.
dorifuto is offline   Reply With Quote
Old 02-02-2013, 07:57 PM   #3
01s0uljah
I made sure the bump stops were replaced with the ones provided by Eibach.
Possible that they fit them in wrong? Im going to bring it back tomorrow and check it out..
Old 02-02-2013, 07:59 PM   #4
Juvenile
Juvenile's Avatar
Drives: 86 GTS
There's a thread somewhere on this happening due to twisting the shaft during installation, still searching for it
found it
http://www.ft86club.com/forums/showt...=eibach&page=3
Old 02-02-2013, 09:19 PM   #5
D1cker
Drives: B9 S4/ND2
Most likely an installation error.
D1cker is offline   Reply With Quote
Old 02-02-2013, 11:54 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm going to go with an impact gun being used.
I had mine on for thousands of miles included track use, zero issues with the damper. Every case I've seen so far has involved installation with an impact gun on the shaft nut.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-03-2013, 12:00 AM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
if you used an impact gun it will blow your shocks due the the shaft spinning inside.
a special tool is needed to disassemble the struts
86_ZN6 is offline   Reply With Quote
Old 02-03-2013, 05:18 AM   #8
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
When I changed the springs on my current car I improvised on the "special tool" and simply used a tap spanner with an allen key through it to hold the piston rod/shaft steady. Works great and costs zero dollars if u already have a set of tap spanners at home.
Fizz is offline   Reply With Quote
Old 02-03-2013, 09:00 AM   #9
Lammie
Lammie's Avatar
Drives: Subaru BRZ
That sucks man, I've had mine for the track and about 6km with no issues.
Lammie is offline   Reply With Quote
Old 02-03-2013, 11:44 AM   #10
Coaster
Coaster's Avatar
Drives: Civic
The spring install DIY recommends an air impact wrench. Is that a mistake?
Step 22.
http://www.ft86club.com/forums/showthread.php?t=10842
Coaster is offline   Reply With Quote
Old 02-03-2013, 11:45 AM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Huge mistake!
Old 02-03-2013, 11:53 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Step 22.
See this post in that thread for some of the suggested tools for removing the top nut: http://www.ft86club.com/forums/showp...1&postcount=50
I use impacts to remove everything else but not that top nut on these OEM struts. I have used impacts on other cars without issue and it's not a sure bet to cause issues on this car either but it's clearly possible based on the number of people who have had this issue.
It also likely depends on who's using the impact. If you do just short bursts with a break in between you likely have better luck than someone just letting it hammer away until the nut is off or fully tightened, etc.
For a sure bet, use hand tools for that nut.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-06-2013, 11:19 PM   #13
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Fitted a set of eibach springs on a buddy's new GT86 last night, and was surprised by how easy it was to remove the top nut for the front strut. What I did was to simply use a long allen key to hold the shaft in place, then fit a deep offset ring spanner around the top nut. With the wheels still on the ground, crack the top nut loose a little. Needed a little force but my ring spanner was long enough to give sufficient leverage. Once this is done then only jacked the car up and proceed with the rest of the strut removal process as per normal.
Rear top nut too deep for my offset spanner to reach in, so had to remove whole strut first before I was able to remove the top nut. But with my buddy holding the strut firmly, it wasn't too difficult to get the job done.
I guess no matter which way you do this (hand tool or air tool), the most important thing to remember is that you must always avoid spinning the shaft.
The only "issue" I had was that I was unable to torque the top nuts back to factory spec. But you should be able to judge going by how much tightness was on the nut when you loosened them. They should be tight, but not He-Man tight.
Old 02-06-2013, 11:24 PM   #14
caliboy15
caliboy15's Avatar
Drives: 1994 NA8
stock shocks and aftermarket springs is a no no
caliboy15 is offline   Reply With Quote
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 48 06-07-2013 02:19 PM
Debating between Sportlines or STANCE coils.. wWaldo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 01-23-2013 11:14 AM
eibach sportlines clunking.. frsguy707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-24-2012 11:42 AM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
