Old 01-21-2013, 06:18 PM   #841
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by BRZPDX View Post
will a 18x8.5 +48 in the front have inner clearance issues? I ordered 12mm spacers just in case..
Yup this set up from Rota will NOT fit in the front. Waiting on spacers now..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following User Says Thank You to BRZPDX For This Useful Post:
ill86 (01-22-2013)
Old 01-22-2013, 03:42 AM   #842
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by fastfrs View Post
17x9 with 30 offset is the wheels. would the fenders sit flush with the wheels? ill be runnign 245/40 tires
Front will be poking on stock suspension settings (camber).
ill86 is offline   Reply With Quote
Old 01-22-2013, 03:49 AM   #843
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Timtamtt View Post
I NEEDED this thread haha thanks for this
So I'm on s techs right now with stock wheels. It's a 2.5 finger drop so I dunno, maybe a drop of an inch and a half. I want to get a set of rpf1s that are 17x9 with a low offset. Here is the problem. In 5x100 they only have 17x9+45. I don't really want my spokes to be at the same level as the face so I was hoping to get a little concave. I plan on getting the project Kics 5x114.3 conversion spacer. It's a 15mm spacer. Then I'll get the rpf1s with a size of 17x9+22 square all around. Will it fit? Not sure what tire size to get it will be x/40/17 not sure about how wide a tire I should get
Thanks,
Tim
17x9 , 245/40 or 255/40
A +22 with 15mm spacer will net +7. That is aggressive fitment.
Vs OE Wheel:
Out 66mm in the front/rear. 16mm more inner clearance.
Poke in rear, 2" poke lol on the front. :-) run a lot of camber.. :-) :-)
The Following User Says Thank You to ill86 For This Useful Post:
Timtamtt (01-22-2013)
Old 01-22-2013, 04:28 AM   #844
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by dori. View Post
let me know how your 18x9.5 rear fits. I have 18x9 +30 but I fear it'll poke more than I like
probably gonna run a 245 on it most likely. thinking about how much stretch/camber I need
Only 5mm more poke than my new ones, shouldn't need anything too aggressive stretch or camber wise.
Old 01-22-2013, 07:05 PM   #845
Sac-BRZ
Drives: BRZ Limited AT
How come some wheels make the tires look more stretched? Both of these are on a 18x9.5 wheel and tires look totally different..
245/45R18 which measures 9.65
255/35R18 which measures 10.04
The wider 255 looks more stretched than the 245..
Sac-BRZ is offline   Reply With Quote
Old 01-22-2013, 07:11 PM   #846
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Different brand tires aren't always exactly how wide they say. For examples NITTO tires run small, a 275 of theirs may be as wide as a Michelin 255.
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
ill86 (01-23-2013)
Old 01-23-2013, 02:13 AM   #847
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
^Truth.
Plus, some tires have that "rim saver" lip that flares out over the rim. If a tire of the same size doesn't have that, the rim will seem to poke more.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-23-2013, 02:13 AM   #848
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Sac-BRZ View Post
[COLOR=black][FONT=Verdana]How come some wheels make the tires look more stretched? Both of these are on a 18x9.5 wheel and tires look totally different..
Different tire manufactures measure differently. As well as sidewall and tread design.
Old 01-23-2013, 07:32 AM   #849
Sac-BRZ
So not only do I have to decide on a wheel out of thousands.. I have to put just as much research into tires now, this should be fun.
Old 01-23-2013, 09:39 AM   #850
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Pure Automotive is offline   Reply With Quote
Old 01-23-2013, 07:43 PM   #851
BRZPDX
Boosted Member
BRZPDX's Avatar
What drop is that?
Old 01-23-2013, 07:44 PM   #852
Pure Automotive
Eibach Pro Kit, 1"
Old 01-27-2013, 09:06 PM   #853
whataboutbob
AutoX-10/10ths every run
I just picked up my 17x9 ET35 RPF1s from LSD Friday. Test fitted the wheel on the car tonight. Rear looks pretty good for clearance as the closest thing is the e-brake cable guide. The fronts I'm not sure about...see photo below. I'm planning on running 245/40R17 Z2s on these. What do you think?
Build thread:Here
Old 01-28-2013, 02:25 PM   #854
JoeBoxer
JoeBoxer's Avatar
Originally Posted by stancypants View Post
hey everyone im new to the frs just got it a few weeks back but im not new to the stance game but with that said what does this set up sound like a 18x10+25 rear thinking of a 225/35 and a 18x9.5 +25 or +30 front and thinking like a 215/40 note im going to be slamming the car going for a good amount of poke. what do yall think i havent seen to many specs on a good slammed with poke frs on here
I will drive to georgia and if you put a 18x10 on a 225/35R18
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
