Old 01-17-2013, 06:27 AM   #827
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
This car seems to fit rather aggressive setups. Probably picking up sti bbs 17x8 7 spokes. With a 25mm spacer/adapter, and a 53mm et that's a 28mm offset right? So the back from my estimation would be pretty good the front would poke some? I searched for sti bbs with no search results.. total BS but I'm on tapa-stutter so cant do a proper search
zohare is offline   Reply With Quote
Old 01-17-2013, 07:03 AM   #828
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
yep.
ZC6BRZ is offline   Reply With Quote
The Following User Says Thank You to ZC6BRZ For This Useful Post:
zohare (01-17-2013)
Old 01-17-2013, 07:44 AM   #829
zohare
zohare's Avatar
Originally Posted by ZC6BRZ View Post
yep.
Thanks! Might try this setup for demo and sell the wheels. Pretty sure I can find some rollers. They're light and not too hard to come by
Old 01-17-2013, 06:01 PM   #830
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
hey guys,
can i run 255/35 tires on rear with 19 x 9.5 +43 with no issues?
dropped with a Eibach Pro Kit.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-17-2013, 09:42 PM   #831
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Will this setup work?
Front:
18x8.5 +35 235/35/18
Rear:
18x9.5 +42 275/35/18
Drop 1" front and rear
Tansey86 is offline   Reply With Quote
Old 01-18-2013, 11:50 AM   #832
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Front:
Rear:
I just got my tires in yesterday, I'm waiting for my wheels
Front:
Rear:
18x9.5 +30 255/35/18
Pure Automotive is offline   Reply With Quote
Old 01-18-2013, 05:20 PM   #833
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
Has anyone tried mounting
265/35/18 on a 9.5 +45?
I don't expect to rub the fender, but I'm curious about inner clearance.
Currently on pro kit w/ stock dampeners
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
The Following User Says Thank You to thatWESguy For This Useful Post:
Tansey86 (01-19-2013)
Old 01-19-2013, 01:33 PM   #834
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
Has anyone asked about gravel rally rims?
Will these fit? or any 15"?
http://passwordjdm.com/Enkei-RCG4-Wheels-C2150.aspx
RazBRZ is offline   Reply With Quote
Old 01-19-2013, 01:45 PM   #835
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
rear would probably be fine, front would most likely hit the strut if you don't have coilovers.
The Following User Says Thank You to JoeBoxer For This Useful Post:
ill86 (01-22-2013)
Old 01-19-2013, 07:49 PM   #836
fastfrs
Drives: frs
17x9 with 30 offset is the wheels. would the fenders sit flush with the wheels? ill be runnign 245/40 tires
fastfrs is offline   Reply With Quote
Old 01-19-2013, 11:17 PM   #837
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Front:
Rear:
let me know how your 18x9.5 rear fits. I have 18x9 +30 but I fear it'll poke more than I like
probably gonna run a 245 on it most likely. thinking about how much stretch/camber I need
dori. is offline   Reply With Quote
Old 01-19-2013, 11:30 PM   #838
Pure Automotive
I was advised by the company I bought the wheels from that +30 would be "flush" fitment, only time will tell, they'll be here Tuesday!
Old 01-20-2013, 12:28 AM   #839
Timtamtt
Timtamtt's Avatar
I NEEDED this thread haha thanks for this
So I'm on s techs right now with stock wheels. It's a 2.5 finger drop so I dunno, maybe a drop of an inch and a half. I want to get a set of rpf1s that are 17x9 with a low offset. Here is the problem. In 5x100 they only have 17x9+45. I don't really want my spokes to be at the same level as the face so I was hoping to get a little concave. I plan on getting the project Kics 5x114.3 conversion spacer. It's a 15mm spacer. Then I'll get the rpf1s with a size of 17x9+22 square all around. Will it fit? Not sure what tire size to get it will be x/40/17 not sure about how wide a tire I should get
Thanks,
Tim
Timtamtt is offline   Reply With Quote
The Following User Says Thank You to Timtamtt For This Useful Post:
ill86 (01-22-2013)
Old 01-21-2013, 12:02 AM   #840
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
will a 18x8.5 +48 in the front have inner clearance issues? I ordered 12mm spacers just in case..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
