Old 01-13-2013, 09:27 PM   #43
gmookher
the install is easy actually, if done right
no harm
tho, as much as I love to mod my car, and I am a patron of Perrins other kit, neither of my cars will get a lightweight pulley. I'm stubborn like that.
Lighter flywheel yes, and even that, I will likely go with the heaviest lightweight I can find..
Old 01-13-2013, 09:33 PM   #44
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
no harm
I understand the reasons why. And if this wasn't a flat 4 I wouldn't have done it myself.. The quality of the pulley is nice, better then the junk they sell for my air cooled nettle engine, but it's ran a light weight pulley for tens of thousands of miles, and after reading up on the engines, I personally felt safe to run one... That said.. Being and auto, I didn't notice a bit of difference, I just barely felt a bit of difference with the intake and exhaust.. Nothing like the people that talk about it.. Making it sound like its gained 20 hp, but again, being an auto it does mask some of the power gains... I'll be at the evasive dyno day next month.. See what it puts down
Gixxersixxerman is offline   Reply With Quote
Old 01-13-2013, 11:28 PM   #45
whataboutbob
AutoX-10/10ths every run
I'll be there too. It'll be interesting to see if all of this $$$ we've spent actually gives us some HP on our ATs.
:happy0180:
Build thread:Here
Old 01-13-2013, 11:49 PM   #46
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Didn't notice any difference on my auto either, not a part I usually recommend for auto guys I'm pretty sure I felt more difference with a drop in filter.
Old 01-14-2013, 02:50 AM   #47
Bluecille
Drives: Scion FR-S Ultramarine
Wow that turned ugly there for a few posts.
I am with the other two guys now...as experienced as I may think I am working on cars the boxer motor is not in my comfort zone. Reading this makes me think twice about buying a pulley kit. I'll have to ask if my dealer would install this item for me. Since they are not underdriven warrenty shouldn't be an issue.
Bluecille is offline   Reply With Quote
Old 01-14-2013, 07:59 AM   #48
cruzinbill
Drives: Argento 6spd FR-S
Its not dampened so warranty mroe than likely will be an issue.
cruzinbill is offline   Reply With Quote
Old 01-14-2013, 08:23 AM   #49
gmookher
not this again...
The Following 4 Users Say Thank You to gmookher For This Useful Post:
Hawk77FT (01-21-2013), kwood9000 (01-14-2013), neutron256 (01-14-2013), SpeedmasterBRZ (01-14-2013)
Old 01-14-2013, 08:41 AM   #50
Noob4Life
86 Noob
Drives: Firestorm FR-S
I hear lightweight pulleys throw off the balance of the engine (if it comes with a harmonic balancer) so I don't see the dealer installing them and allowing you to keep your warranty. Not dissing on the pulleys seeing as I have lightweight pulleys installed on my jetta. Probably one of the easiest mods I have done to my car. IDK how much different the boxer engine is but if it's about the same then my advice would be, if you can't even install a new pulley without messing something up and trying to make the dealer pay for your mistake I would stop doing your own mods from now on OP.
Noob4Life is offline   Reply With Quote
Old 01-14-2013, 10:02 AM   #51
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Tbh I you aren't comfortable doing this install then let someone who knows what they are doing install it. The reason this failed was improper installation. This should not reflect upon the quality of this product. Perrin knows what they are doing. About the part swapping debate here's my 2 cents. Only swap out parts if it might be questioned about affecting warranty work. If you caused the problem though you should hold yourself responsible. No reason to be denied warranty work because you had an aftermarket part on that has nothing to do with the problem.
SubaSteve is offline   Reply With Quote
The Following 2 Users Say Thank You to SubaSteve For This Useful Post:
gmookher (01-14-2013), kwood9000 (01-14-2013)
Old 01-15-2013, 09:19 AM   #52
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Any updates??
Cajun is offline   Reply With Quote
Old 01-17-2013, 12:14 AM   #53
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Originally Posted by No5ki View Post
This must be the same pulley install as the Boeing 787... what could go wrong...
Legitimately humorous.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 01-17-2013, 05:44 PM   #54
Hops Normal
Hops Normal's Avatar
Drives: 2013 Scion FR-S Peral White
You know I'm really disappointed in some of the people on this forum. I expected support from the people that share the love for there cars and some of you are just plain assholes. Not everyone is as knowledgeable as most ppl on this forum and some of us are still learning things. I learned that sometimes things go wrong with simple installs. I really hope if anything ever happens to your car you get support instead of other assholes like you. However I do know there are quite a few ppl that are supportive on here and I am greatful for that. Let me say thank you to those of you who are not pricks
As for the car the dealership has it right now. They are going to replace the seal and some other things the guy told me about as well as filing down the key a little because it got a burr on it. I will update when I have more info.
Sent from my SPH-L710 using Tapatalk 2
Hops Normal is offline   Reply With Quote
The Following 8 Users Say Thank You to Hops Normal For This Useful Post:
2forme (01-17-2013), brybot (01-02-2017), Cajun (01-17-2013), FasterpromsFRS (01-17-2013), Freeman (01-18-2013), fuddbutter (01-17-2013), kwood9000 (01-17-2013), neutron256 (01-17-2013)
Old 01-17-2013, 05:49 PM   #55
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by 2forme View Post
LOL @ people calling that fraud, as if they wouldn't do the same....
That sucks man. I've had my pulley on for 4000 miles and have had no issues. Try checking the balance of the Perrin pulley, they could have gotten a bad stock of aluminum.
Seriously? People thanked this post?
Are you kidding me? Not only is he accusing the entirety of the forum of being fraudulent scum bags, he also seems to think that bad base material makes for bad machining and can cause the factory part that was removed to simultaneously be bad also in the same manner.
Old 01-17-2013, 05:51 PM   #56
Cajun
Cajun's Avatar
Hops- I have to agree with you. I have hardly any knowledge about cars, and when I ask a question, many times the responses I get are filled with smart ass answers.
The Following 3 Users Say Thank You to Cajun For This Useful Post:
BoostedWrbBrz (01-18-2013), Julio86 (01-17-2013), neutron256 (01-17-2013)
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin pulley instalation for AT help Teknian_Culprate13 Engine, Exhaust, Transmission 7 01-21-2013 11:43 PM
Perrin Pulley ArKiTeCkT Issues | Warranty | Recalls / TSB 12 11-06-2012 11:57 AM
Pulley install issue Boxer-86 Engine, Exhaust, Transmission 9 10-21-2012 07:37 PM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
