Drives: 2013 Scion FR-S Peral White
Perrin pulley install gone wrong
So I installed my perrin pulley today just like the DIY on here said. Then I got in my car and drove it for a minute. I got out of the car to let my buddy drive it and we hear a small knocking noise. We went back to the house and found that oil had exploded all over the engine bay. When we tryed to find the problem we had no luck all I know is the pulley wobbles before u start it. I have uninstalled the pulley and put the stock one back on and it does the sake thing. Any ideas? I need help.
Sent from my SPH-L710 using Tapatalk 2 |
how did you torque the bolt down after install?
AutoX-10/10ths every run
I paid http://www.infamousperformance.net to install mine. I watched them do the install and I seem to remember that there was some sort of O-ring seal behind the pulley. I have had no oil leak issues.
I'd check your oil level ASAP, and then take it to someone who is an expert on these motors. If it is pissing oil everywhere it might be better to have it towed in. I wouldn't drive it!!! Good luck.
crank walk?
Drives: FRS :D
Pictures?
Also manual or auto?
Out of the FRS game
Gotta be crooked and you possibly may have damaged the key-way or the key itself.
It is manual. And I think I might just have the road side assistance tow it to the dealer. I'm just worried about how much this is going to cost
Drives: 86
swap to the stock pulley unless you wanna lose your warranty as illegal as that is, it'll save your butt in the long run. unless you wanna take responsibility for installing it wrong. then have them tow your car to a shop either way.
NASA SpecE30 Racer
The dealership is going to know that the problem was caused by the OP. Please don't advocate he commit fraud. It sounds like you have damaged the oil seal. Hopefully it can simply be replaced fairly easily.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#10 |
Drives: Attitude
#11 |
Ya I'm definaly not trying to commit fraud. Im just worried this is going to cost alot of money.
#12 |
Drives: the girls crazy
Probably did'nt see the O-ring came off, mine did that(came off no mess) it was a pain to put it back in place
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
#13 |
any time you play be ready to pay
#14 |
Drives: 2013 Subaru BRZ MT Limited
If the pully is wobbling it sounds like you did not line up the key on the pulley to the key on the crank. Also you need to make sure like others said to check and make sure the o-ring seal on the front of the crankshaft didn't come off with the old pulley.
The biggest thing is making sure the alignment key's on both the pulley and the crank seat together properly. If they are not seated properly, the pulley will not be aligned properly and will wobble on the crankshaft and possibly damage other things and chew up your fan belt.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
| Aftermarket Crank Pulley Install | Enigmus | DIY (Do-It-Yourself) Guides | 305 | 02-05-2019 12:37 AM |
| Perrin pulley instalation for AT help | Teknian_Culprate13 | Engine, Exhaust, Transmission | 7 | 01-22-2013 12:43 AM |
| Perrin Pulley | ArKiTeCkT | Issues | Warranty | Recalls / TSB | 12 | 11-06-2012 12:57 PM |
| Pulley install issue | Boxer-86 | Engine, Exhaust, Transmission | 9 | 10-21-2012 08:37 PM |
| Camshaft Bolt Coming Loose After Perrin Pulley Install | WhiteBRZ | Engine, Exhaust, Transmission | 25 | 09-20-2012 09:07 AM |
