go_a_way1
Old 01-10-2013, 07:09 PM   #799
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Originally Posted by ill86 View Post
245/35 or
255/35
As in staggered?
white_knight is offline   Reply With Quote
Old 01-10-2013, 07:27 PM   #800
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
As in staggered?
No. As in two choices. Hence the "or".
You gave a square setup. I gave two (square) options back. :-)
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
white_knight (01-10-2013)
Old 01-10-2013, 07:37 PM   #801
white_knight
Oh, got it
255 does sound like a lot of tyre -- no rubbing in the front?
Old 01-10-2013, 07:53 PM   #802
ill86
ill86's Avatar
Drives: iG FR-S
That, my friend, is your homework. :-)
I was simply answering your questions. Not solving the puzzle for you.
:happy0180:
If I have the time I'll do some on-car measurements for you in the next few days. Crawl under yours and measure the clearance between your OEM tire and suspension. Report back and I'll plug some numbers.
Old 01-10-2013, 08:09 PM   #803
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Anyone running RCE Yellows with camber bolts and 265/35-18s on 18x9s?
I plan on running Konis with it but they shouldn't effect camber/offset, just the bolts and lowering springs.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-10-2013, 10:00 PM   #804
DC-FRS
Drives: Whiteout FR-S
Hey guys,
Finally settled on some XXR 530s in 18/8.75/+33 (square setup).
Attachment 24979
Just shopping around for some tyres. Other than personal preference, is there an ideal size tyre to fit these wheels? I want to go as wide as possible. I'm also planning on lowering about 1".
I just bought these same wheels haha. My post right above yours was about these lol. Where'd you order from?
DC-FRS is offline   Reply With Quote
Old 01-10-2013, 11:39 PM   #805
Mitch
form follows function
Drives: RIP '13 BRZ
Oh, got it
I'm running 255/40/17 on a 17x8+45. I didn't get rubbing on my stock autocrosses or my first autocross lowered on KWs, but I did on my second. I'm going to work on figuring out where it's rubbing and what ride height prevents it before/at my next autocross.
Mitch is offline   Reply With Quote
The Following User Says Thank You to Mitch For This Useful Post:
ill86 (01-11-2013)
Old 01-11-2013, 12:07 AM   #806
Suffa
Drives: Black GTS
Im waiting on prices but im thinking of a setup of front: 18x8.5(+45), rear: 18x9.5(+45). Saw earlier here someone with same setup and the reply was it would fit nicely. If i go this setup what tyre sizes i need?
If i decide to go 17"s though my options are 17x8(+40 or +45) and 17x9(+45). If i go the 17's whats the best setup and tyre size selection?
Edit: Will be dropped 1"
Suffa is offline   Reply With Quote
Old 01-11-2013, 12:31 AM   #807
JoeBoxer
JoeBoxer's Avatar
I ran 235/40 on my XXR 530's, great for even at stock height but better lowered. Way cheaper than 245 or 255/35's too
Old 01-12-2013, 12:36 AM   #808
seven
Tells it like it is
seven's Avatar
No one eh?
Old 01-12-2013, 12:46 AM   #809
ayau
Drives: Some rust bucket
265? Is this for stance? Depending on the wheel offset, you might be hitting the front strut or get some pretty heavy fender rubbing.
Old 01-12-2013, 12:57 AM   #810
seven
Tells it like it is
seven's Avatar
+38 offset
Not for stance... More for having a good bit of rubber under the car on the street to deal with the power (turbo kit).
A could people did Eibach pro kit with 255s and they are kinda close but RCEs don't lower as much... was wondering if the 10mm more would fit (maybe with fender rolling).
Old 01-12-2013, 01:33 AM   #811
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
+38 offset
A could people did Eibach pro kit with 255s and they are kinda close but RCEs don't lower as much... was wondering if the 10mm more would fit (maybe with fender rolling.
If you are worried about the front I don't think lowering changes the geometry. Only the rear gains negative camber with a drop.
digital_assassin is offline   Reply With Quote
Old 01-14-2013, 09:33 AM   #812
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Do you have any pics? I'm still debating this setup, I originally wanted to go staggered 17x8 front 17x9 rear, but the wheels I've been looking at don't come bigger than 17x8.
Pure Automotive is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
