#29 | |
86 Noob
Drives: Firestorm FR-S
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
#31 | |
Drives: Asphalt FRS
#32 |
Drives: '13 Ultramarine
You don't have the car yet? Try it out first...the ride is firm, but not at all harsh. I expected it to be pretty stiff, but it is actually not bad, and I use my car as a daily driver. As others have said, adjustable struts will help, but this is not going to be cheap. I am running 16" winter tires and the ride is noticeably softer than with the summer 17s. Impreza springs probably wouldn't be a good idea, even if they fit. They are designed for a heavier car, and would give you a "4X4" stance (and most likely ride like one too).
| The Following User Says Thank You to roddy For This Useful Post: | PeterB (12-31-2012) |
#33 |
Señor Member
Drives: white BRZ 6MT
WAIT A MINUTE... WAAAAIIIIT A MINUTE.
you don't have the car yet? uhm wtf? You definitely don't know what it's like to drive the car day to day. I thought the car was stiff at first but now I'm used to it (and could go a tad stiffer TBH). A test drive isn't really going to show you the car's dynamics, unless you get it for a week or something.
| The Following User Says Thank You to dori. For This Useful Post: | Wolfking (12-23-2012) |
#34 |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
You're really going to need a coilover setup to run softer springs - and you'll have to spec in the springs yourself because there's not going to be a single sane brz owner seeking aftermarket suspension to make the car handle worse than stock.
As mentioned here also, you can run 16" wheels and tires with larger sidewalls. This should be easier to find since there are sane performance reasons to run a smaller rim/tire on this car, which means you can piggyback on the sanity of others to pursue your ridiculous goal. -Justin
| The Following User Says Thank You to Justin.b For This Useful Post: | PeterB (12-31-2012) |
#35 | |
If the ride is still too harsh, then I'd try custom rate springs (or swapping in the FR-S front springs as mentioned above). |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | PeterB (12-31-2012) |
#36 |
Drives: Raven Black
Try to set of Yokohama tires. They turned my SLK into a real luxury car.
| The Following User Says Thank You to berndawg For This Useful Post: | PeterB (12-31-2012) |
#37 |
Drives: Whiteout FR-S
#38 | |
Drives: 1992 Nissan 240SX
There are plenty of cars that weigh over two tons that have harsh, choppy rides due to improper damper valving and excessively low sidewall profiles. Mass is not the issue. I'm in the same boat as the OP- I want a less harsh ride but for different reasons- I like to drive fast over choppy pavement and tires that aren't on the road don't provide a heck of a lot of grip. It seems to me that properly valved dampers and stiffer springs combined with a reduction in bushing stiction, as well as a decrease in unsprung weight, will create a car with superior ride quality and grip over rough pavement. It just won't be inexpensive and I'm okay with that. OP, the least expensive choice will probably be a change to 215/50R17 tires, as you'll gain nearly half an inch of sidewall height. No other changes would be necessary. You'll lose feedback and accuracy and a tiny bit of braking stability, and you'll have more shoulder wear when you push the car hard, but the ride will be better. |
| The Following User Says Thank You to SOneThreeCoupe For This Useful Post: | PeterB (12-31-2012) |
#39 |
Drives: Attitude
My winter tires (205/50/17) over choppy pavement makes me want to die. I started thinking a lot more about ride comfort after this thread; moving to such a different compound with more sidewall DID make the ride bouncier. Want 50 degree or higher temps back NAO so I can has stiff ride back!
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | PeterB (12-31-2012) |
#40 |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Check into the Tein H Tech springs. I don't know personally, but I do hear they are a bit softer than stock. It's not going to be super easy to make this car too soft though.
| The Following User Says Thank You to Jaylyons1 For This Useful Post: | PeterB (12-31-2012) |
#41 |
AutoX-10/10ths every run
Buy my stock FR-S springs when I put my RaceCompEngineering springs on.
#42 |
Not softer than stock but ride is excellent and the drop is pretty decent. I like them but actually would like something a little stiffer.
| The Following User Says Thank You to JoeBoxer For This Useful Post: | PeterB (12-31-2012) |
| 'Fluttering'/soft rattle at speed | Symbiont | BRZ First-Gen (2012+) — General Topics | 35 | 12-22-2016 01:23 PM |
| Soft and hard dial... No homo | _F-R-S_ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 12-07-2012 12:22 PM |
| What's your other ride, winter ride etc. | wtout86 | Other Vehicles & General Automotive Discussions | 13 | 12-07-2012 12:36 AM |
| Soft Clutch fix | Billy2224 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 07-01-2012 05:03 PM |
| Soft Touch Materials in car are easily scratched! | Spd229 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 06-21-2012 11:05 PM |
