Old 12-20-2012, 10:54 PM   #1
PeterB
PeterB's Avatar
Drives: Subaru BRZ Limited WRB
I want a soft ride
BRZ is too stiff for me. How can I make it more comfy and softer ride? I know this is going to be controversial on the forum and contrary to what most people preferences are.
In order to improve logistics here, please do not make the following comments:
1. This car is not for you. You should buy a different car. I know it, but I like this car.
2. Softening will worsen the handling. I know.
I want the softest ride in BRZ that is still safe and not too expensive.
I already know general guidelines like these:
http://www.ehow.com/how_7254664_soft...-ride-car.html
but they are not likely to change the ride significantly, I think.
So, what are my choices about changing the suspension?
I would appreciate any feedback.
PeterB is offline   Reply With Quote
Old 12-20-2012, 10:54 PM   #2
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
Sell it and buy a Prius. There's really nothing to do other then maybe thicker sidewall tires. Most people are trying to do the exact opposite. And that's what all after market suspension options will do. Make the ride stiffer.
BoostedWrbBrz is offline   Reply With Quote
The Following 2 Users Say Thank You to BoostedWrbBrz For This Useful Post:
GT86drifter (12-21-2012), Wes (12-21-2012)
Old 12-20-2012, 11:00 PM   #3
Hanakuso
Go find someone that will custom build a set for you
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
PeterB (12-21-2012)
Old 12-20-2012, 11:18 PM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
If you can find softer springs, then that and tires is all you can really do.
The Following User Says Thank You to boredom.is.me For This Useful Post:
PeterB (12-21-2012)
Old 12-20-2012, 11:56 PM   #5
PeterB
PeterB's Avatar
So, does anybody know about softer springs that will fit BRZ?
Old 12-20-2012, 11:58 PM   #6
Noob4Life
86 Noob
Drives: Firestorm FR-S
Just get a larger tire or upgrade your shocks. If you get a high quality after market shock like blisten maybe, with the stock springs it will probably make for a better ride. But to be honest if you wanted a soft ride you should've bought a luxery sedan not a sports car...
Noob4Life is offline   Reply With Quote
The Following 2 Users Say Thank You to Noob4Life For This Useful Post:
dori. (12-22-2012), PeterB (12-21-2012)
Old 12-21-2012, 12:18 AM   #7
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
De-inflate tires a bit? stock it's at 36 psi which is pretty high.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
PeterB (12-21-2012)
Old 12-21-2012, 01:16 AM   #8
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Go down to 16" wheels with either 225/50 or 215/55 touring style tires.
Don't touch the suspension except for maybe some chassis bracing. Also get some sound deadening too since you probably want it quieter too.
JoeBoxer is offline   Reply With Quote
The Following User Says Thank You to JoeBoxer For This Useful Post:
PeterB (12-21-2012)
Old 12-21-2012, 10:19 AM   #9
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
It's a lightweight car. Your only going to be able to make the ride so soft before it will start to become unstable. Part of how nice big luxury cars have such a smooth ride is the have a lot of mass.
The Following User Says Thank You to neutron256 For This Useful Post:
PeterB (12-21-2012)
Old 12-21-2012, 10:46 AM   #10
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
16's with meatier tires is your only reasonable option other than getting someone to build you a new set of shocks custom valved.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
PeterB (12-21-2012)
Old 12-21-2012, 11:31 AM   #11
djdnz
1337
Drives: 2013 BRZ WRB S/C
Yup, smaller wheels, bigger tires should help a bit. Plus you can brag that you bought them small because they are lightweight
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
PeterB (12-21-2012)
Old 12-21-2012, 11:41 AM   #12
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Sorry but it's the first thing that came to mind when I read the title. My wife wants a more comfy ride - I tell her to drive her own car.
rmjjensen is offline   Reply With Quote
The Following User Says Thank You to rmjjensen For This Useful Post:
Mikepage (12-25-2012)
Old 12-21-2012, 11:56 AM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
Sorry but Logistics is the management of the flow of resources between the point of origin and the point of destination in order to meet some requirements (eg: shipping).
I agree 16" wheels with 50 or 60 series tires will do it. Also maybe KW V3's at the softest setting. Neither of those options are cheap.
The Following User Says Thank You to wbradley For This Useful Post:
PeterB (12-21-2012)
Old 12-21-2012, 03:21 PM   #14
mla163
Overthinking it
Drives: BRZ in CS
I would start with the dampers first. Try some adjustable Konis. See if that improves the ride at all.
I am not sure if there are any springs out there that would fit with a lower rate (Impreza springs, maybe?)
Next, you could try a coilover setup. Ground Control, for example. And get a lighter rate of springs.
Honestly, I think the ride is pretty good as is. If you want to soften the car up, then it kind of ruins the point of having a well handling sports car.
mla163 is offline   Reply With Quote
The Following User Says Thank You to mla163 For This Useful Post:
PeterB (12-21-2012)
'Fluttering'/soft rattle at speed Symbiont BRZ First-Gen (2012+) — General Topics 35 12-22-2016 01:23 PM
Soft and hard dial... No homo _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 12-07-2012 12:22 PM
What's your other ride, winter ride etc. wtout86 Other Vehicles & General Automotive Discussions 13 12-07-2012 12:36 AM
Soft Clutch fix Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2012 05:03 PM
Soft Touch Materials in car are easily scratched! Spd229 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 06-21-2012 11:05 PM
