Old 12-01-2012, 07:44 PM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Soft and hard dial... No homo
I just got bc coilovers on and lowered 1 and half inches. Just tryin to figure out how to use these hard soft dials effectily and at what point will a difference be noticed if i put on hard
_F-R-S_ is offline   Reply With Quote
Old 12-01-2012, 07:48 PM   #2
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
start closer to soft, and adjust from there until you have the stiffness/ride manner you like
Jesse is offline   Reply With Quote
Old 12-01-2012, 08:25 PM   #3
gonbrz
Drives: World Rally Blue BRZ
when i had it on my SI i kept it in the middle and it was great.
i had it harder one time and with in 15 min on the interstate my back was killing me.
like @Jesse says you will have to play with the setting to find the best for you, i would recommend starting in the middle
gonbrz is offline   Reply With Quote
Old 12-01-2012, 08:49 PM   #4
_F-R-S_
How do i know where its at right now
Old 12-01-2012, 09:05 PM   #5
Dezoris
Dezoris's Avatar
And thus the problems with coilovers. The only way to get the best setting is to first corner balance the car and then tune them at a track for consistent/fast lap times. For street its basically totally different, get the car corner balanced which may not work for the street anyway. Then spend a ton of time adjusting front vs rear stiffness. The general rule is front slightly stiffer rebound than rear. So near medium/soft for front and a soft in rear. Its guess work for street tuning. The firmer the rebound in rear the more oversteer.
Old 12-01-2012, 09:17 PM   #6
_F-R-S_
Ill mess around with it next weeekend. Unfortuanatly these are just my winter coilovers so no corner balance so it really just does t matter. Thanks for info
Old 12-02-2012, 12:08 AM   #7
Jesse
wheel gap
Jesse's Avatar
to know, click them all the way soft ( - ), and adjust from there 3-5 clicks up to start
The Following User Says Thank You to Jesse For This Useful Post:
_F-R-S_ (12-05-2012)
Old 12-02-2012, 12:35 AM   #8
gonbrz
if i remember correctly there are a total of 30 clicks on my bc coilovers i had them at 15 clicks
The Following User Says Thank You to gonbrz For This Useful Post:
Old 12-05-2012, 01:27 AM   #9
sandman126
Slide Ways
sandman126's Avatar
Drives: 2013 SWP BRZ, 85 VW Golf
Yep, there are 30 clicks, turn them all the way soft (counter clockwise) then start counting clicks once you start stiffening them up. My 05 legacy gt i had em set 8 in front and 5 in the rear when i was DDing it, so smooth. Then when i would track it, i would turn it up to 20 front, 15 rear. Can't wait to order a set for my BRZ
sandman126 is offline   Reply With Quote
The Following User Says Thank You to sandman126 For This Useful Post:
Old 12-05-2012, 03:12 AM   #10
_F-R-S_
Great info thanks agaim
Old 12-05-2012, 11:38 AM   #11
chutrain
chutrain's Avatar
Drives: WRB BRZ
I believe you are supposed to start with full firm and then back off from there. Not from the full soft setting.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 12-06-2012, 02:23 PM   #12
sandman126
Slide Ways
sandman126's Avatar
Not on BC's, according to their instructions anyway. It says you're actually suppose to reset to full soft before you adjust them each time.
Old 12-07-2012, 12:22 PM   #13
d1ck
Drives: Black 2013 FRS
This is because of a phenomenon called hysteresis, and makes perfect sense. Also, soft or hard, it shouldn't matter.
d1ck is offline   Reply With Quote
The Following User Says Thank You to d1ck For This Useful Post:
sandman126 (12-07-2012)
'Fluttering'/soft rattle at speed Symbiont BRZ First-Gen (2012+) — General Topics 35 12-22-2016 01:23 PM
Voice recognition dial with iphone4s? jadewbj Electronics | Audio | NAV | Infotainment 9 09-19-2012 06:20 PM
Presets and speed dial lookchris Electronics | Audio | NAV | Infotainment 0 07-25-2012 11:08 AM
Soft Clutch fix Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2012 05:03 PM
Soft Touch Materials in car are easily scratched! Spd229 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 06-21-2012 11:05 PM
