Old 12-15-2012, 02:48 PM   #15
number1Tango
Drives: Silver FRS
Originally Posted by SLOPPYDRFT26 View Post
not k&n. you want a dry filter. oiled filters screw with the maf sensor
i haven't read anywhere that you have to oil that filter.. could be wrong.
number1Tango is offline   Reply With Quote
Old 12-15-2012, 04:09 PM   #16
Foobar
SLO NO MO
Foobar's Avatar
Not true.
The Following User Says Thank You to Foobar For This Useful Post:
Jesse (12-26-2012)
Old 12-15-2012, 10:47 PM   #17
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
Originally Posted by Darryljr11 View Post
Make sure whichever intake you get you unplug the negative battery line to reset the ECU. The ECU should then be able to adjust to the increased air flow.
will this solve the CEL and allow the vehicle to run properly rather then running lean?
corvino26 is offline   Reply With Quote
Old 12-15-2012, 11:08 PM   #18
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
im installing the Takeda intake tomorrow and will definitely make sure to keep the battery unplugged the length of the install and i will update everyone accordingly... wish me luck !
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
The Following User Says Thank You to ScionFR-S For This Useful Post:
Darryljr11 (12-16-2012)
Old 12-16-2012, 12:04 AM   #19
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by 86_ZN6 View Post
save your money.
use a drop in filter instead
I will probably doing this also .
Mikepage is offline   Reply With Quote
Old 12-16-2012, 12:09 AM   #20
corvino26
corvino26's Avatar
Best of luck! I am looking forward to your findings.
Old 12-16-2012, 12:18 AM   #21
corvino26
corvino26's Avatar
save your money.
I'm looking for increased throttle response that comes from having a solid pipe and better breathing that comes with a cone air filter. Obviously make a custom heat shield or buy an intake system that has a heat shield, a throatier sound from the intake that doesn't require a sound tube to the cabin and over all a slight horsepower gain BUT I am looking for a system that will bolt up without leaning out the car. The fix so far seems to be installing the intake and or any parts with the battery disconnected. I don't want to have to look into a piggie back ecu until I want to turbo up. Thank you for your advice but there is a method to my madness that won't suffice by a drop in air filter.
Old 12-16-2012, 08:59 AM   #22
2forme
The Injen will lean out the car even with an ECU reset (battery disconnect).
Originally Posted by wrmathis View Post
i think he's refering to that they do make an intake. just not a cold air one. it pulls air from the hot engine compartment so calling it a cold air intake is wrong
This.
Old 12-16-2012, 09:12 AM   #23
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I love that u guys are worried about the insignificant amount "leaning" an intake may or may not change.
TouchMyHonda is offline   Reply With Quote
The Following User Says Thank You to TouchMyHonda For This Useful Post:
Old 12-16-2012, 09:15 AM   #24
Opposed
Drives: 2013 Asphalt FR-S
Maybe do a drop in filter and a silicone intake pipe???
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 12-16-2012, 10:50 AM   #25
corvino26
corvino26's Avatar
This.
So then whichever way I look at it I'm going to need to tune the engine huh?
Old 12-16-2012, 11:01 AM   #26
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Stock with k &n
Sent from my iPad using Tapatalk HD
RWD-boxer is offline   Reply With Quote
Old 12-16-2012, 11:27 AM   #27
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
i dont know i never had the CEL issue
Darryljr11 is offline   Reply With Quote
Old 12-16-2012, 11:37 AM   #28
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Since people "claim" the injen intake makes your car run lean no matter what but can you actually prove it? Everyone I know in MD with the kit has had no issues whether they have an ecu tune or not. By the way its a short ram intake not a cold air intake but the filter does sit right in front of the snorkel thats supposed to draw in outside air albeit with a opening that allows some air from the engine bay to come in.
Best intake? Maps316 Engine, Exhaust, Transmission 34 05-12-2014 03:15 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
Looking for HKS Intake Spartan65 Engine, Exhaust, Transmission 2 09-12-2012 10:40 PM
