#15 | |
Drives: Silver FRS
i haven't read anywhere that you have to oil that filter.. could be wrong.
#17 |
Drives: 2013 Scion FR-S 6MT Raven
will this solve the CEL and allow the vehicle to run properly rather then running lean?
A.Corvino
http://www.streetmasters.com/ |
#18 |
Drives: Raven Scion FR-S
im installing the Takeda intake tomorrow and will definitely make sure to keep the battery unplugged the length of the install and i will update everyone accordingly... wish me luck !
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
| The Following User Says Thank You to ScionFR-S For This Useful Post: | Darryljr11 (12-16-2012) |
#19 |
Drives: Scion FR-S 2013 Raven
#20 |
Best of luck! I am looking forward to your findings.
A.Corvino
#21 |
I'm looking for increased throttle response that comes from having a solid pipe and better breathing that comes with a cone air filter. Obviously make a custom heat shield or buy an intake system that has a heat shield, a throatier sound from the intake that doesn't require a sound tube to the cabin and over all a slight horsepower gain BUT I am looking for a system that will bolt up without leaning out the car. The fix so far seems to be installing the intake and or any parts with the battery disconnected. I don't want to have to look into a piggie back ecu until I want to turbo up. Thank you for your advice but there is a method to my madness that won't suffice by a drop in air filter.
A.Corvino
#22 | |
This. |
#23 |
Vtec Jesus
I love that u guys are worried about the insignificant amount "leaning" an intake may or may not change.
| The Following User Says Thank You to TouchMyHonda For This Useful Post: | Darryljr11 (12-16-2012) |
#24 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#25 |
So then whichever way I look at it I'm going to need to tune the engine huh?
A.Corvino
#26 |
Drives: Black
Stock with k &n
Sent from my iPad using Tapatalk HD |
#27 |
Sideways and Smiling!
Drives: Scion FR-S
#28 |
Drives: Scion FR-S
Since people "claim" the injen intake makes your car run lean no matter what but can you actually prove it? Everyone I know in MD with the kit has had no issues whether they have an ecu tune or not. By the way its a short ram intake not a cold air intake but the filter does sit right in front of the snorkel thats supposed to draw in outside air albeit with a opening that allows some air from the engine bay to come in.
| Best intake? | Maps316 | Engine, Exhaust, Transmission | 34 | 05-12-2014 03:15 PM |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 08:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 01:31 PM |
| Looking for HKS Intake | Spartan65 | Engine, Exhaust, Transmission | 2 | 09-12-2012 10:40 PM |
