Drives: 2013 Scion FR-S 6MT Raven
What is the best intake for FR-S?
I have been looking into the agency power intake for my FR-s BUT it has just came to my attention that it seems most intakes cause a cel and cause the frs to run lean. I would like to know what u guys think would be the best intake to buy without having to get a tune. Also keep in mind I intend on also purchasing a cat back and cat delete pipe. Thanks for any and all thoughts.
A.Corvino
http://www.streetmasters.com/ |
Drives: 86 ZN6
save your money.
use a drop in filter instead |
Drives: Silver FRS
Drives: Firestorm FR-S
For mine i'm going to install an Injen Cold- Air and probably the TRD exhaust later on.
DADA
Drives: 2013
Afe intake hasn't caused any cel with the fa20club tune
-AKA |
Drives: 2024 MT Toyota GR86
Drives: 07CivicSI
not k&n. you want a dry filter. oiled filters screw with the maf sensor
Sideways and Smiling!
Drives: Scion FR-S
Make sure whichever intake you get you unplug the negative battery line to reset the ECU. The ECU should then be able to adjust to the increased air flow.
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Only if over-oiled. I have the aFE oiled drop-in and I have no issues.
#10 |
Drives: Scion FR-S
I have the injen and it has been awesome for me but other people have had issues with them. I normally work on old muscle cars and I know an exhaust with no negative pressure can cause them to run rich and an intake can cause them to run lean so it is finding a balance and adjusting the carb. Not sure if the same applies to this car being fuel injected but I had an exhaust on mine before the intake.
Sent from my SGH-T989 using Tapatalk 2 |
#11 | |
#12 |
#13 |
Check again.
#14 |
Drives: no car :(
| Best intake? | Maps316 | Engine, Exhaust, Transmission | 34 | 05-12-2014 03:15 PM |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 08:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 01:31 PM |
| Looking for HKS Intake | Spartan65 | Engine, Exhaust, Transmission | 2 | 09-12-2012 10:40 PM |
