Old 11-16-2012, 11:26 AM   #393
ayau
Drives: Some rust bucket
Originally Posted by noodleface View Post
Would you go 205/45/17 on the stock wheels? Or stick with 215/45/17? I know from NASIOC they run wide.
Don't quote me but I think 215/45/17 is a more common size, which means the tires will be cheaper. I'd just stick to 215.
Old 11-16-2012, 11:30 AM   #394
empower-auto
Kouki-Monster
empower-auto's Avatar
If you ran a tire like this in a configuration whereas a normal tire would have some stretch on the wheel - would one of these fill out better / be less stretched?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-16-2012, 11:32 AM   #395
ayau
Originally Posted by danthedirt View Post
Looking at running a similar setup with the same rubber. Would love to hear the thoughts of the wheel gurus here. Subbed.
Wider does not always mean better performance. If you don't care for performance/safety, then this will not be relevant to you. In general, you can't go wrong sticking to the factory tire specs but upgrading to a stickier compound.
This is a very helpful document regarding wheels and tires.
http://www.tuneruniversity.com/blog/...t-people-down/
The Following 2 Users Say Thank You to ayau For This Useful Post:
danthedirt (11-16-2012), rikdrt1 (11-16-2012)
Old 11-16-2012, 11:34 AM   #396
ayau
Can you rephrase your question? I'm not sure what you're asking.
Old 11-16-2012, 11:47 AM   #397
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
I was about to pull the trigger and go to a slightly wider 7.5 or 8" .. but i started reading about the height that these add as well. (in 17" format)
i like the stock low-profile look, and the wider tires will give you higher sidewalls.. if you're like me and like playing in the canyons on the wknd - thats something to think about.
i decided to stick wit stock tires and maybe pick up the 215's in StarSpec -- that alone will add about an inch of width and nothing on the sidewall. that would be best for me.
just something to think about ...
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 11-16-2012, 11:51 AM   #398
empower-auto
Kouki-Monster
It's not hard. Read it again.
Rich Anderson
EMPOWER AUTO
Old 11-16-2012, 11:56 AM   #399
ayau
You can go up to 8" wide on the wheels on 215 tires and it won't affect the height of the overall wheel. I think you got them mixed up.
Once you go to 235 and wider tires, you'll want 40 series sidewalls in order to keep the same overall height of the wheel. However, I don't recommend going with wider tires unless you plan to swap out suspension components too. Anything that's wider than 225, you'll be looking at your suspension being the weakest link in your car IMO.
Old 11-16-2012, 11:58 AM   #400
ebphoto
Drives: FR-S, NA8, S13
more than likely.
federals fit bigger.. the 195/50/15s rsr i had on my corolla fit like 205s.
ebphoto is offline   Reply With Quote
Old 11-16-2012, 12:04 PM   #401
ayau
Yes, they will look less stretched. As mentioned earlier, all tires are not the same even if they have the same specs.
For example, You'd have to be running 8.5 and wider to get that "stretched" look on 215 star specs. However, 8" wide wheels will look "stretched" on oem tires.
Old 11-16-2012, 02:27 PM   #402
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
17X7.5 on stock size tires ?
Im looking at the Enkei PF's -- in as close as stock as i can get --
I noticed that tirerack says to move up to 225/45/17 for this size... but is that the widest it can take safely ?
what happens or is it recommended to use the 215/45's - on a rim size that is bigger than the stock 7" ?
or does that strectch the tire ? - ive heard that term but not sure what that means ---
Old 11-16-2012, 04:46 PM   #403
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I did. The name of the thread and the topic of the first post concerns stretching the turanza's over some 8" enkeis.
He never said anything about getting the summer tires that he wants in 215. That's something you extrapolated from nowhere.
dori. is offline   Reply With Quote
Old 11-16-2012, 04:54 PM   #404
dori.
Señor Member
dori.'s Avatar
ok nevermind, whatever
Old 11-17-2012, 12:20 AM   #405
SilentAngel
Guest
Posts: n/a
Hi, i am wanting to put either of these 2 sets of rims
http://www.wheeldude.com/catalog/pro...oducts_id=1107
http://www.wheeldude.com/catalog/pro...oducts_id=5760
on these tires
http://www.tirerack.com/tires/tires....e+Sport+COMP-2
but i dont know anything about rim size or tire size and dont know what would be the best fitment without rubbing on the stock suspension set up.
Old 11-17-2012, 05:33 AM   #406
diddy
diddy's Avatar
Drives: 2013 BRZ Sport-Tech
Will the 18x9.5 fit on stock suspension?
diddy is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
