| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#393 |
Drives: Some rust bucket
#394 |
Kouki-Monster
If you ran a tire like this in a configuration whereas a normal tire would have some stretch on the wheel - would one of these fill out better / be less stretched?
Rich Anderson
EMPOWER AUTO |
#395 | |
This is a very helpful document regarding wheels and tires. http://www.tuneruniversity.com/blog/...t-people-down/ |
| The Following 2 Users Say Thank You to ayau For This Useful Post: | danthedirt (11-16-2012), rikdrt1 (11-16-2012) |
#396 |
#397 | |
Hypnotic FRS Member
Drives: FR-S [Raven]
i like the stock low-profile look, and the wider tires will give you higher sidewalls.. if you're like me and like playing in the canyons on the wknd - thats something to think about. i decided to stick wit stock tires and maybe pick up the 215's in StarSpec -- that alone will add about an inch of width and nothing on the sidewall. that would be best for me. just something to think about ...
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports- SoCAL |
#398 |
Kouki-Monster
It's not hard. Read it again.
Rich Anderson
EMPOWER AUTO |
#399 | |
Once you go to 235 and wider tires, you'll want 40 series sidewalls in order to keep the same overall height of the wheel. However, I don't recommend going with wider tires unless you plan to swap out suspension components too. Anything that's wider than 225, you'll be looking at your suspension being the weakest link in your car IMO. |
#400 |
Drives: FR-S, NA8, S13
#401 |
Yes, they will look less stretched. As mentioned earlier, all tires are not the same even if they have the same specs.
For example, You'd have to be running 8.5 and wider to get that "stretched" look on 215 star specs. However, 8" wide wheels will look "stretched" on oem tires. |
#402 |
Hypnotic FRS Member
17X7.5 on stock size tires ?
Im looking at the Enkei PF's -- in as close as stock as i can get --
I noticed that tirerack says to move up to 225/45/17 for this size... but is that the widest it can take safely ? what happens or is it recommended to use the 215/45's - on a rim size that is bigger than the stock 7" ? or does that strectch the tire ? - ive heard that term but not sure what that means --- |
#403 |
Señor Member
Drives: white BRZ 6MT
I did. The name of the thread and the topic of the first post concerns stretching the turanza's over some 8" enkeis.
He never said anything about getting the summer tires that he wants in 215. That's something you extrapolated from nowhere.
#404 |
Señor Member
ok nevermind, whatever
#405 |
Guest
Posts: n/a
Hi, i am wanting to put either of these 2 sets of rims
http://www.wheeldude.com/catalog/pro...oducts_id=1107 http://www.wheeldude.com/catalog/pro...oducts_id=5760 on these tires http://www.tirerack.com/tires/tires....e+Sport+COMP-2 but i dont know anything about rim size or tire size and dont know what would be the best fitment without rubbing on the stock suspension set up. |
#406 |
Drives: 2013 BRZ Sport-Tech
Will the 18x9.5 fit on stock suspension?
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
