| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#379 |
Drives: Whiteout FR-S
#380 |
Drives: Asphalt FR-S
I was able to pick up 2 brand new from a local. The price was ridiculously good. I'm stuck with the +45, but the photos I've seen still look good and better than stock.
I'm not thrilled to run the stock 215s but I don't want to waste them either. I'll prob go with a 235/40 when they wear down. |
#382 |
Drives: Toyota 86 GTS
Gotcha. I read it as he was ordering tyres however after re-reading I now understand he is ordering wheels.
#383 |
Since you have to order 2, you could get a pair of +35's for the rear. You wouldn't be able to rotate without dismounting but it would look a little more flush.
#384 |
#385 |
Drives: 1986 Toyota Corolla
TE37SL in 18X9.5 +22 FTW
#386 |
Drives: 2004 Toyota Camry V6 LE
Federal 595RS-R fitment on a 17x7.5 wheel
I've been trying to do much research on these tires and have almost concluded that they run ~18mm wider than they actually state.
Does anyone have personal experience with these? I was looking at purchasing 225/45/R17's, but am considering going down to 215's instead. I'm not sure if my wheels are wide enough to appropriately accommodate these Federals.
#387 | |
Drives: Some rust bucket
Also, wider does not always mean better. Wider tires will take a longer time to reach its optimal operating temperature. 215 is plenty wide for our cars given their power/weight IMO. |
#388 |
#389 | |
Señor Member
Drives: white BRZ 6MT
the turanza is just the tire they started using in place of the bichelins that the car originally came with. it's an OEM tire.
#390 |
#391 |
Drives: '13 BRZ Ltd WRB/'17 STI CWP
Would you go 205/45/17 on the stock wheels? Or stick with 215/45/17? I know from NASIOC they run wide.
#392 |
Hadouken
Looking at running a similar setup with the same rubber. Would love to hear the thoughts of the wheel gurus here. Subbed.
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
