go_a_way1
Old 11-15-2012, 07:24 PM   #379
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by fender9530 View Post
Thank you! I was able to get a great deal on 2. Need to order the other 2 yet. Ill need a good vendor for those...and lugs.
same place you got the exhaust? NLM...
Old 11-15-2012, 07:32 PM   #380
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
I was able to pick up 2 brand new from a local. The price was ridiculously good. I'm stuck with the +45, but the photos I've seen still look good and better than stock.
I'm not thrilled to run the stock 215s but I don't want to waste them either. I'll prob go with a 235/40 when they wear down.
fender9530 is offline   Reply With Quote
Old 11-15-2012, 07:33 PM   #381
fender9530
fender9530's Avatar
Good call. I'll have to give him a call tomorrow for wheels and lug nuts.
And I wasn't going to rush into any mods
The Following User Says Thank You to fender9530 For This Useful Post:
JoeBoxer (11-15-2012)
Old 11-15-2012, 07:35 PM   #382
Stance86
Drives: Toyota 86 GTS
Gotcha. I read it as he was ordering tyres however after re-reading I now understand he is ordering wheels.
Stance86 is offline   Reply With Quote
Old 11-15-2012, 07:44 PM   #383
JoeBoxer
JoeBoxer's Avatar
Since you have to order 2, you could get a pair of +35's for the rear. You wouldn't be able to rotate without dismounting but it would look a little more flush.
Old 11-15-2012, 08:36 PM   #384
fender9530
fender9530's Avatar
That did cross my mind. Hmm.
Old 11-16-2012, 04:49 AM   #385
style86
Drives: 1986 Toyota Corolla
TE37SL in 18X9.5 +22 FTW
style86 is offline   Reply With Quote
Old 11-16-2012, 05:02 AM   #386
RidgeRacerJM
Drives: 2004 Toyota Camry V6 LE
Federal 595RS-R fitment on a 17x7.5 wheel
I've been trying to do much research on these tires and have almost concluded that they run ~18mm wider than they actually state.
Does anyone have personal experience with these?
I was looking at purchasing 225/45/R17's, but am considering going down to 215's instead. I'm not sure if my wheels are wide enough to appropriately accommodate these Federals.
RidgeRacerJM is offline   Reply With Quote
Old 11-16-2012, 05:24 AM   #387
ayau
Drives: Some rust bucket
Extreme summer tires generally run wider than eco tires. Bridgestone re11 215/45/17 can accommodate up to 8" wide tires. I would recommend sticking with 215.
Also, wider does not always mean better. Wider tires will take a longer time to reach its optimal operating temperature. 215 is plenty wide for our cars given their power/weight IMO.
Old 11-16-2012, 05:27 AM   #388
RidgeRacerJM
Thanks for the reply!
Old 11-16-2012, 05:49 AM   #389
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Stance86 View Post
If you are going to the expense of buying new tyres I would have thought you would want to run a wider tyre to suit your 8 inch wide wheels. Stretch is usually only used to fit over width wheels on.. It will look a bit silly running a 215 on an 8 inch wide wheel, especially in a +45.. Each to their own, not having a go at you just curious.
what? he's not buying new tires?
the turanza is just the tire they started using in place of the bichelins that the car originally came with. it's an OEM tire.
dori. is offline   Reply With Quote
Old 11-16-2012, 08:20 AM   #390
Stance86
Read all the posts.
Old 11-16-2012, 10:48 AM   #391
noodleface
Drives: '13 BRZ Ltd WRB/'17 STI CWP
Would you go 205/45/17 on the stock wheels? Or stick with 215/45/17? I know from NASIOC they run wide.
noodleface is offline   Reply With Quote
Old 11-16-2012, 11:17 AM   #392
danthedirt
Hadouken
danthedirt's Avatar
Looking at running a similar setup with the same rubber. Would love to hear the thoughts of the wheel gurus here. Subbed.
Whiteout MT
Car Blog: downrightfrs.blogspot.com/
danthedirt is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
