| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#337 | |
Drives: Whiteout FR-S
#338 | |
NW Region Moderator
Drives: FR-S No More
Check this topic: http://www.ft86club.com/forums/showthread.php?t=7535 Scroll down to the Drag Wheel section and there is a link to the DR-34 in 17x7.5. Hope that helps.
#339 |
Drives: 2013 FR-S, raven
Basically I want this:
![]() Since I have a Raven and a full TRD kit on already, this is pretty much the exact look I am going for. Now, from the source of this pic, I get the sense that these are 18 x 9.5 (but the offset is +45 all around) I am hearing conflicting things from different vendors as well (apparently the +40 offset is for the US market and the black edition is a standard color, whereas for the +45 the pressed graphite is a standard color) I am trying to stay away from the murdered look and that is why I'd really want the pressed graphite finish instead. Since I am still on stock suspension (waiting for Eibach to release the multi pro R1s) I guess I cant really run these wheels as they will hit the stock spring perches |
#340 |
Yeah that looks good, the black one's don't look that bad i like this setup and would work on stock suspension...
http://www.ft86club.com/forums/showthread.php?t=18670 |
#341 |
Drives: 2013 Raven FR-S
i honestly have no clue. i'm gonna have to do some inner measuring and/or contact wheeldude. seems people have problems with much narrower tires so idk how this is possible, but he did it without any mods of any sort. it's not like there's any crazy amount of camber being used either...
#342 |
Drives: Toyota 86 GTS
Well I'll soon find out.. RPF1s on the way..
#343 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
U get SBC?
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#344 |
I didn't want SBC but its all I could get.. So SBC on Fuji red, should look interesting.
#345 |
My FR-S has 5 gears
Color combo will look great, but be careful with the tire size... 255/35 is already a pretty thin sidewall(for a spring drop)... and if u do a 245/35 you're gonna have a ton of wheel gap
Omar GC
#346 |
I hear what you are saying and might go for a 40 profile but to be honest my car is a daily so it's not going to be too crazy anyway...
#347 |
Kouki-Monster
@WheelDude.com managed 18x9.5 + 38 all around. I think it was Rota's with 255 tires.
only lowering springs were used to it shouldn't be an issue. the question is what tire size to use. I am leaning towards 245/40 or 245/35. 255 is simply more tire than I want to run.
Rich Anderson
EMPOWER AUTO |
#348 |
Hypnotic FRS Member
Drives: FR-S [Raven]
+48 vs +35 on almost stock sizes
if i end up swapping my stockers for 17x7.5 or 17x8 ....
what are the disadvantages or issues with running something other than the stock 45/48 offset wheels ? there must be a reason Toyota/Scion didnt make the stock ones 35's .. but im just guessing now. Im about to pull the trigger on some aftermarket wheels -- in the 17's -- but want to make sure i understand the issues behind changing the offset all the way around and making it 'poke' out slightly. thx |
#349 |
Drives: Ultramarine FRS(MT), IS350(sold)
I am not an expert but
http://www.8thcivic.com/forums/wheel...ow-offset.html This link might be helpful |
#350 |
Country Boy 4 Life
I am not an expert.
I went with 17x7.5 +40 wheels with stock tires, a conservative setup. The wheel flushes out much better than stock. I am planning on switching the stock tires to some 235/40's. Out of the two specs you have listed, 17 x 8 +35 will fit nice. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
