Old 09-10-2012, 04:57 PM   #71
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Anyone know if the following will fit on stock suspension?
F 18x8.5 +35, R 18x9.5 +40 with 245/35/18 tires all around?
shu5892001 is offline   Reply With Quote
Old 09-11-2012, 08:06 AM   #72
Subynewbie
Subynewbie's Avatar
Drives: 2013 swp brz
Originally Posted by JoeBoxer View Post
I would probably go with 8.5 +38 front and 9.5 +38 rear, many others have and it fits well I don't see any reason to go more aggressive but i'm sure its possible with some negative camber and slightly stretched tires.
Would it still fit well with the Eiback pro-kit springs and their 1 inch drop?
Thx
Subynewbie is offline   Reply With Quote
Old 09-11-2012, 12:03 PM   #73
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Thx
Of course
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Subynewbie (09-11-2012)
Old 09-12-2012, 06:35 PM   #74
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
Interested in seeing if anyone has tried 18x9.5 +40 with a 235/40/18 on the front. I know someone has tried 9.5 +38 with a 215/35, but I was curious to see if the larger tire will rub against the suspension components.
Also, what would the difference be with coilovers vs springs.
Autofashion | FIVEaxis | Enkei
thatWESguy is offline   Reply With Quote
Old 09-13-2012, 01:25 AM   #75
RYU
RYU's Avatar
Drives: really slow...
Hi Guys,
I'm heavily considering buying a set of wheels with this exact same specs.
I'll be lowered 20mm on the RCE Yellows so it won't be very much drop. I don't have the luxury of slamming the car to gain more camber (i.e. tuck) so I'd like your opinions on fitment with these. I really would prefer flush to tuck versus poke. I'm also not a huge fan of too much stretch so i'm hoping you guys can help me decide on tire sizing also. I'm guessing the wheels I have in mind are too aggressive right?
Here's the closest I can find would be these but I'm still not sure on how much pokage.
Klutch SL14 18x8.5 +38 / 18x9.5 +42
Rotiform NUE 18x8.5 +35 / 18x9.5 +35
Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38
RYU is offline   Reply With Quote
Old 09-13-2012, 11:19 AM   #76
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by RYU View Post
Hi Guys,
The front will need a little negative camber. (1-2°)
The rear will sit ideal to what you want. (flush)
Front tire 235 or 245.
Rear tire 255 or 265.
RYU (09-13-2012)
Old 09-13-2012, 02:36 PM   #77
techsmitty
Drives: 2013 BRZ Tech
Any ideas if Prodrive GC-06D's in 17" x 8" 43mm offset and 5x100 will fit?
techsmitty is offline   Reply With Quote
Old 09-13-2012, 08:00 PM   #78
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
my question for all of you: 18x9 +35
should fit fine in the back, but I'm pretty sure it'll poke up front
so if I'm dropped an inch and get the camber bolts, will I fit? probably have to stretch too, no?
I know if the offset were higher there'd be no problem.
seriously? of course. that fitment is very safe.
dori. is offline   Reply With Quote
Old 09-13-2012, 08:18 PM   #79
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
18x9 +35 with 20mm drop i think you will be ok, its pushing it for sure but when i look at this pic i think it will be ok.
http://www.ft86club.com/forums/showp...9&postcount=90
Old 09-14-2012, 07:57 PM   #80
WhiteBRZ
Drives: White BRZ
Will these tires fit?
I have to drive my BRZ during the winter months. With that being said I have a friend who said that I could have his old snow tires for free if they'll fit. Will 215/55/17 tires fit on the stock rims and be drivable?
WhiteBRZ is offline   Reply With Quote
Old 09-14-2012, 08:14 PM   #81
dori.
Señor Member
dori.'s Avatar
why not? they're just taller is all. it's going to throw off your speedo a teensy bit but who cares.
Old 09-14-2012, 08:53 PM   #82
baldolera
baldolera's Avatar
Drives: None Yet
It'll be fine, just make sure his wheels are 5X100 bolt pattern or they won't fit.
Edit: Oops... just realized it was only tires and not a tire & rim package.
Originally Posted by LexusFman View Post
Nope because I have had Keichii Tsuchiya skills from the womb and I'm a beast at Gran Turismo. Reall cars can't be all different.
baldolera is offline   Reply With Quote
Old 09-16-2012, 11:21 AM   #83
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Arrow Will these Rota G-Force Fit ?
hey guys im new to this forum and i have a quick question, im putting winter tires on my stock FR-S rims and i am going to get These Rota Grids for my black FR-S , what would be the best fitment for tire and rim and will these ultimately fit , im going for a high performance summer tire since i wont be using them in the winter time over here in NY... Thanks alot !
http://www.wheeldude.com/catalog/pro...oducts_id=6330
ScionFR-S is offline   Reply With Quote
Old 09-16-2012, 12:28 PM   #84
lookchris
lookchris's Avatar
Should fit real well bro I'm actually going for the same fitment.
Are you planning on lowering your car as well?
lookchris is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
