Old 08-03-2012, 09:02 PM   #1
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Noise Generator Delete Plug Dimensions
This is intended for those who want to make their own plugs for the noise generator delete. If you're just looking directions on how to remove the noise generator there is a far better DIY for that here:
http://www.ft86club.com/forums/showthread.php?t=7975
Edit:
I appreciate the interest but I don't have any extras, or the desire to start making or selling plug sets at this time. I suggest contacting some of the forum's vendors to let them know you're interested. I'm sure if there are enough buyers there will be someone who has the right resources to make at least a limited production run.
If someone wants to copy my design and sell it feel free I'd be flattered.
-All measurements are in inches
-I'm lucky enough to have access to a machine shop with a lathe, but I'm sure there are other ways plugs could be fabricated. Be creative!
-I used Delrin because it's easy to machine and excellent for applications like this (plus I had some laying around) but you could substitute with just about any material that's suited for the heat of the engine compartment
-I decided to go with a full delete back to the firewall. This requires one plug at the intake, and one at the firewall.
-Tolerances don't need to be all that precise since the plugs go into rubber fittings, but if built to these dimensions they will fit great.
Let me know what you think, and if you decide to make your own I'd love to see pics.
I designed the firewall plug a little longer because it's hard to reach and a little better grip doesn't hurt.
This was the best picture I could get of where the plug goes into the firewall. It's not visible but once you feel where the noise generator goes it's not hard to find by touch.
The Intake Plug
The Following 5 Users Say Thank You to neutron256 For This Useful Post:
Black Tire (02-24-2013), cobrabyte (08-05-2012), frs23 (08-09-2012), huma (08-04-2012), tripjammer (03-28-2013)
Old 08-04-2012, 02:14 AM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I added this topic as a link inside of the Noise Generator Delete topic:
Old 08-05-2012, 08:51 PM   #3
xcelir8brz
Drives: 2013 BRZ Limited
Looks really good. Nice alternative to what I did.
xcelir8brz is offline   Reply With Quote
Old 08-09-2012, 08:00 PM   #4
frs23
frs23's Avatar
Drives: FR-S H Lava
I see the diameter of the intake plug is 1.59" on neutron256's drawings. What is the inner diameter of the original hose that goes into the intake outlet hole (the front end hose of the noise generator) ?
Another question is without the clamp tighten how loose or how much space between the noise gen intake hose and the intake outlet to the hose?
frs23 is offline   Reply With Quote
Old 08-09-2012, 08:10 PM   #5
neutron256
neutron256's Avatar
I'm not quite understanding what you're asking. Maybe it would help if you explained what you're trying to do.
Are you thinking of making a plug that goes into the intake side of the noise generator while leaving it in place?
Old 08-09-2012, 09:04 PM   #6
frs23
frs23's Avatar
Drives: FR-S H Lava
Sorry that is wasn't clear, but yes that is what I'm thinking. Thanks!
Old 08-09-2012, 09:19 PM   #7
neutron256
neutron256's Avatar
Okay makes sense. I thought about doing something like this but then decided I wanted the whole thing gone.
The inner diameter is 1.31" (33.27mm). This would be tricky because it has a hard metal insert to support the clamp on the outside of it.
An expanding plug like xcelir8BRZ used for his might work if you can find the right size.
http://www.ft86club.com/forums/showthread.php?t=10800
I would be careful though you don't want anything that could come loose and get sucked further down into the intake.
Let us know what you come up with. It's a great idea if you can find a way to make it work.
The Following User Says Thank You to neutron256 For This Useful Post:
frs23 (08-16-2012)
Old 08-16-2012, 05:45 PM   #8
frs23
frs23's Avatar
Drives: FR-S H Lava
Ok thanks for all the info.. If I come up with anything I'll let you know. The other trick for me is to find time to work on it. Cheers!
Old 08-16-2012, 05:52 PM   #9
neutron256
neutron256's Avatar
I know the feeling. Never enough time, or money to pursue all the ideas I have rattling around in my head.
Old 10-10-2012, 04:52 AM   #10
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
i like the firewall plug... let me know if you start to make and sell both of them... I really like that theyre in black
RAWR BRZ is offline   Reply With Quote
Old 10-10-2012, 11:57 AM   #11
neutron256
neutron256's Avatar
Sorry just not worth it. Someone had approached me about using my design and selling them, but I haven't seen anything since.
The demand for these vs. the cost to produce them just doesn't work out.
Old 10-10-2012, 12:24 PM   #12
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Thank you. I'd really like to know if this modification made that much of a difference or not. Was it worth the effort?
whaap is offline   Reply With Quote
Old 10-10-2012, 05:32 PM   #13
neutron256
neutron256's Avatar
For me it made a big difference. It's much quiter inside the cabin especially on the passenger side (or so my wife tells me). The noise generator produces a hollow higher pitch sound then I like (sounds like an exhaust leak to me) and I'm happy it's gone.
Old 10-10-2012, 11:06 PM   #14
Skye
Drives: TR2,CooperS,BRZ
Does the modification make any difference to performance/warranty/reliability. I would like a quieter cabin.
Skye is offline   Reply With Quote
noise generator, plug, resonator
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 02:24 AM
Noise Generator Delete for $10.00 xcelir8brz Engine, Exhaust, Transmission 85 11-23-2014 02:39 PM
Trunk Dimensions? kmbkk Electronics | Audio | NAV | Infotainment 7 08-20-2013 12:00 AM
FA20 Dimensions Matador Engine, Exhaust, Transmission 9 07-31-2013 01:45 AM
Cabin induction noise delete kit gtauto Engine, Exhaust, Transmission 0 07-27-2012 11:48 PM
