Old 06-05-2012, 06:27 PM   #1
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Trunk Dimensions?
I want to fabricate a sub box & put it into the spare tire area. Has anyone taken the time to pull out the spare tire & other stuff in the trunk & measure the dimensions? I want to make a false floor and raise it to the level of the bottom of the rear seat opening. This should give me enough clearance for 2 8's and the amps. I would do it but it's pouring here. I just thought about it on the way home, so if no one has does this I'll try to tomorrow.
kmbkk is offline   Reply With Quote
Old 06-05-2012, 08:30 PM   #2
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Assuming you are going to remove the spare, you won't need to raise the floor. There is enough airspace in the tire well for two 8's. Then remove the foam at the front, and put your amp there.
Lil Abner is offline   Reply With Quote
Old 06-05-2012, 08:38 PM   #3
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Yeah, I was going to remove all the foam and make a false floor. The reason I mentioned raising the floor is the 8's have a mounting depth of about 5-5.5"
Old 06-05-2012, 08:43 PM   #4
Lil Abner
Well, I can tell you that the foam inside the spare is around 4.5" thick. So add another 2-3" (at least) for the spare (floor to hub), and you'll have plenty of room.
Old 06-05-2012, 08:46 PM   #5
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Sweet...thanks!
Old 08-19-2013, 12:31 PM   #6
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Bringing this back from the land of the dead. Can someone please give me the trunk dimensions? I'm designing an enclosure for the front of the trunk area (under the package tray) and need the width, height, and top and bottom depth from the back of the rear seat to the trunk opening! I would get it myself but I'm deployed. Again.
Thanks in advance!
Old 08-19-2013, 03:13 PM   #7
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
this link may help
http://www.cars101.com/subaru/brz/br...tml#dimensions
shiumai is offline   Reply With Quote
Old 08-19-2013, 11:00 PM   #8
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
The link does help, thanks! The only measurements left that I need are the depth from the back seat (top & bottom) to the opening.
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
FA20 Dimensions Matador Engine, Exhaust, Transmission 9 07-31-2013 12:45 AM
Trunk Swap? Coconut Cosmetic Modification (Interior/Exterior/Lighting) 1 04-25-2012 09:47 PM
Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt BRZman BRZ First-Gen (2012+) — General Topics 48 09-03-2011 11:32 PM
