Old 05-26-2012, 12:53 PM   #1
Matador
hashiryu
Drives: Mk4 Supra
FA20 Dimensions
I don't know if I might have missed this in the deluge of new information, but has any of the guys that have measured, taken apart, swapped the 86/BRZ/FR-S been able to get the dimensions on the FA20 boxer engine?
l*w*h but most importantly weight (dry or wet, doesn't matter) is what I'd like to know.
Anyone?
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 05-28-2012, 09:01 AM   #2
Matador
hashiryu
Drives: Mk4 Supra
Sooo, nobody then?
The Following User Says Thank You to Matador For This Useful Post:
Brzzee (07-30-2013)
Old 05-28-2012, 09:31 AM   #3
Jonny Rochester
Drives: 1983 Corolla Levin
86mm x 86mm. Bore and stroke. (Same as 3S-GE I'm told).
The Subaru FB20 has a longer stroke, so the FA20 is recast as a different block.
Jonny Rochester is offline   Reply With Quote
Old 05-28-2012, 02:53 PM   #4
Matador
hashiryu
Drives: Mk4 Supra
Thanks, but not boreXstroke. Exterior dimensions.
Old 05-28-2012, 04:53 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
About this wide, by this tall, by this high. *holds out hands*
Old 05-28-2012, 04:53 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-28-2012, 05:16 PM   #7
Sasquachulator
Pavement Grey
Shouldnt it be pretty simlar to an FB or the EJ motors (ok well maybe closer to the FB than the EJ)?
Old 05-28-2012, 05:23 PM   #8
Dimman
Kuruma Otaku
Dimman's Avatar
Matador, from what it sounds like, the exterior of the FB and FA blocks are probably the same. Height reduction from a lower intake manifold, and a shallower steel oil pan are probably the only differences. Width is probably identical since the stroke is only 4mm shorter and they wouldn't bother to recast a smaller block for that. Casting-wise they would only be using different cores inside the same main dies anyways. Length is also going to be only accessory differences, I bet.
So it will fit inside any space that an FB will.
Probably.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Matador (05-29-2012)
Old 07-30-2013, 11:20 PM   #9
Lateapex
Drives: WRB BRZ
bump for this info?
Lateapex is offline   Reply With Quote
Old 07-31-2013, 12:45 AM   #10
Turdinator
Señor Member
Turdinator's Avatar
Probably.
I imagine the heads will be different though and that may change the width a bit.
OP the engine is pretty accessible with the hood open. I would imagine you could get some pretty accurate measurements with the motor still in place if you wanted to. Just not the weight.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Hawk77FT (07-31-2013)
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
FA20 for sale coyote AUSTRALIA 1 12-01-2011 12:53 AM
Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt BRZman BRZ First-Gen (2012+) — General Topics 48 09-03-2011 11:32 PM
