Old 09-16-2024, 06:10 PM   #15
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Can I you to fly out to Virginia and test my car?
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Teseo (09-26-2024), Ultramaroon (09-17-2024)
Old 09-17-2024, 01:09 AM   #16
If you're patient enough to get four pins connected without touching each other, and you're down for back and forth for a week or so, I bet I could walk you through all the rest. At worst, you're out fifty bucks.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (09-25-2024), blsfrs (09-17-2024), T-Steve (09-17-2024), Teseo (09-26-2024)
Old 09-17-2024, 01:33 PM   #17
blsfrs
blsfrs's Avatar
The blue line makes sense to me. The blips are the notches. What is the yellow line reading? I told you I was a nube.
Is there any way to get ecutek data logging to give me oscilloscope function?
Also, I ordered an ecu from LKQ on Ebay. They sent me a DI driver even though their description clearly stated the module was under the dash. To their credit, they immediately refunded the full amount. I'm still looking for an ecu just so I can rule it out as the problem.
The Following User Says Thank You to blsfrs For This Useful Post:
jflogerzi (09-24-2024)
Old 09-17-2024, 01:40 PM   #18
No problem! The yellow trace (channel-1) is the crankshaft position signal. Going back to the Subaru TSB, the high-to-low transition (falling edge) is the important part of the camshaft signal. They use the crankshaft signal for reference.
edit: CAN data is of no help here. We are monitoring raw signal (analog) from the sensors exactly as they are seen by the ECU.
If we see good signal going into the ECU, that input channel of the ECU must be at fault.
If we see bad signal, we go down the shim-swapping road.
If we see no signal, something is wrong with the wiring. I'd suspect the connector between main and engine harnesses. I say this only because the fault code remained the same after you swapped sensors. That was a good test.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (09-25-2024), blsfrs (09-17-2024), NoHaveMSG (09-25-2024), Tatsu333 (09-18-2024), Teseo (09-26-2024)
Old 09-24-2024, 11:43 PM   #19
jflogerzi
jflogerzi's Avatar
Link has a new plug and play module.... for our cars and its what ASM recomends. 2K
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
blsfrs (09-25-2024)
Old 09-25-2024, 10:59 AM   #20
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Trainspotting vibes.
(don't lend O'scope money)
The Following 2 Users Say Thank You to bcj For This Useful Post:
blsfrs (09-25-2024), Ultramaroon (09-25-2024)
Old 09-25-2024, 01:07 PM   #21
Sadly, I think I have frightened off any takers. I promise that it looks way more intimidating than it actually is.
edit: With the WiFi connection, one could be monitoring in real time while fiddling with the sensor as the engine idles.
bcj (09-25-2024)
Old 09-25-2024, 02:11 PM   #22
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I could be mistaken but I thought it was for the fa20. I assumed it wouldn't work for the fa24.
autoracer86 is offline   Reply With Quote
Old 09-25-2024, 02:25 PM   #23
bcj
Geo Tyrebighter Esq
bcj's Avatar
I was only riffing on all the spikes.
Solid breadboarding skills demonstrated and why they should be encouraged.
When I saw this one, it initially looked like you were shoving the pins through the insulation.
RToyo86 (11-14-2024), Ultramaroon (09-25-2024)
Old 09-25-2024, 03:21 PM   #24
jflogerzi
jflogerzi's Avatar
snice ASM is recommending using it with there hybrid FA20/FA24 builds it should... Guessing it needs FA20 engine harness on the gen 1 vs the new Gen 2s
autoracer86 (09-27-2024)
Old 09-25-2024, 05:48 PM   #25
Ah, yes. I'm not above that as a last resort, and even then, only with interior wires.
Hell, I was conflicted about messing with the virgin connectors for the demo. "If it ain't broke..."
bcj (09-26-2024)
Old 10-01-2024, 11:57 AM   #26
Tatsu333
Drives: 2020 BRZ Sport Tech RS
An important note from Link's product website for the new Link ECU for those with 2017+ FA20's (or looking to connect directly to an FA24, since I believe they use the same type of crank sensor and DI Fuel Pressure sensor as the 2017+):
"Note: 2017+ Models have some differences to earlier cars and will not run with the sample maps supplied in PCLink and the standard plug-in ecu hardware.
  • 2017+ Engines have a Hall Effect Crank Sensor instead of Reluctor and so require the Trigger 1 Type changed from 'Reluctor' to 'Optical/Hall' and the Trigger 1 Pull-up set to ON.
  • 2017+ Engines have a different DI Fuel Pressure sensor than earlier models, this sensor has 4 pins instead of 3 and requires an 8.2kohm pullup resistor to be wired between C7 (An Volt 4) and 5v, the DI Fuel Pressure Source changed from An Volt 3 to An Volt 4 and the pressure calibration changed to 4119.6kPa at 3.62V and 9790.6kPa at 2.94V."
Tatsu333 is offline   Reply With Quote
The Following 3 Users Say Thank You to Tatsu333 For This Useful Post:
autoracer86 (10-01-2024), blsfrs (10-01-2024), T-Steve (10-01-2024)
Old 11-14-2024, 08:04 PM   #27
blsfrs
blsfrs's Avatar
Ok folks, here's where we are. My FRS is on it's way to RS Motors, Inc. Ron is determined to fix the P0341 code problem. After fixing it, he will do a custom tune and ship the car back to me in Va. I'll post his findings and fixes.
I have a lot of admiration for Ron and his company. He is very invested in his customers and wants his products to be flawless. I have no doubt my car will be perfect when I get it back.
The Following 6 Users Say Thank You to blsfrs For This Useful Post:
makinen (11-17-2024), NoHaveMSG (11-14-2024), T-Steve (11-14-2024), Tatsu333 (11-18-2024), Ultramaroon (11-15-2024)
Old 11-14-2024, 09:23 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That’s cool he is wanting to fix it. Hopefully prevents the issue in the future.
blsfrs (11-15-2024)
Another FA24 swap blsfrs Engine Swaps 40 12-21-2024 10:59 AM
FA24 swap to a GT86 ? Anything I need be aware of? twasd Engine Swaps 23 01-09-2024 10:28 PM
Viability of complete FA24 swap (motor and ECU)? Tatsu333 Engine Swaps 43 02-18-2023 06:18 PM
P0341 Code being thrown on 2020 brz ts bbearchell Issues | Warranty | Recalls / TSB 4 08-06-2022 05:42 PM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
