Drives: 2020 White BRZ ts
P0341 Code being thrown on 2020 brz ts
I heard about the sprockets on earlier models but I heard they fixed that. Any other ideas? Car is running fine.
Professional Mechanic
Drives: 2017 86 6MT Oceanic
P0341 is a circuit range-performance code. A mechanical failure isn't impossible, but rather limited to physical damage to the tone wheel or a sprocket that has jumped a tooth.
There is a fancy diagnostic chart that makes you check every wire, the tone wheels and even take the cover off to check the valve timing, but this is really one of those codes that's easier to do the old fashioned way: Mark the B1 intake camshaft position sensor with a paint pen, remove it, look in the hole while turning the engine over 2 turns. Is the tone wheel ok? If yes, remove the B2 intake camshaft position sensor and switch them. See if the etc turns into a P0345. If it stays on 341 now you've got reasonable doubt to have a go at the harder steps. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | Ultramaroon (08-06-2022) |
Will the mechanic at Subaru know about this?
Sent from my Pixel 5 using Tapatalk |
Drives: WRB BRZ
| P0340 P0341 can’t get cleared | PostBRZtranny | Issues | Warranty | Recalls / TSB | 1 | 08-03-2022 02:29 AM |
| p0365, p0366, p0340, p0341 | blsfrs | Engine, Exhaust, Transmission | 8 | 05-31-2021 09:30 AM |
| Help - Two Codes Thrown | jpit | Engine, Exhaust, Transmission | 3 | 04-20-2013 12:52 AM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
| P0341 | Jaknar | Issues | Warranty | Recalls / TSB | 1 | 01-14-2013 01:59 PM |
