| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: 2013 frs base
Can I you to fly out to Virginia and test my car?
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | Teseo (09-26-2024), Ultramaroon (09-17-2024) |
#16 |
If you're patient enough to get four pins connected without touching each other, and you're down for back and forth for a week or so, I bet I could walk you through all the rest. At worst, you're out fifty bucks.
#17 |
The blue line makes sense to me. The blips are the notches. What is the yellow line reading? I told you I was a nube.
Is there any way to get ecutek data logging to give me oscilloscope function? Also, I ordered an ecu from LKQ on Ebay. They sent me a DI driver even though their description clearly stated the module was under the dash. To their credit, they immediately refunded the full amount. I'm still looking for an ecu just so I can rule it out as the problem. Last edited by blsfrs; 09-17-2024 at 02:47 PM. |
| The Following User Says Thank You to blsfrs For This Useful Post: | jflogerzi (09-25-2024) |
#18 | |
edit: CAN data is of no help here. We are monitoring raw signal (analog) from the sensors exactly as they are seen by the ECU. If we see good signal going into the ECU, that input channel of the ECU must be at fault. If we see bad signal, we go down the shim-swapping road. If we see no signal, something is wrong with the wiring. I'd suspect the connector between main and engine harnesses. I say this only because the fault code remained the same after you swapped sensors. That was a good test.
#19 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | blsfrs (09-25-2024) |
#20 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Trainspotting vibes.
(don't lend O'scope money)
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | blsfrs (09-25-2024), Ultramaroon (09-25-2024) |
#21 |
Sadly, I think I have frightened off any takers. I promise that it looks way more intimidating than it actually is.
edit: With the WiFi connection, one could be monitoring in real time while fiddling with the sensor as the engine idles.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | bcj (09-25-2024) |
#22 |
Drives: Toyota GT86
I could be mistaken but I thought it was for the fa20. I assumed it wouldn't work for the fa24.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#23 |
Geo Tyrebighter Esq
I was only riffing on all the spikes.
Solid breadboarding skills demonstrated and why they should be encouraged. When I saw this one, it initially looked like you were shoving the pins through the insulation.
| The Following 2 Users Say Thank You to bcj For This Useful Post: | RToyo86 (11-14-2024), Ultramaroon (09-25-2024) |
#24 |
snice ASM is recommending using it with there hybrid FA20/FA24 builds it should... Guessing it needs FA20 engine harness on the gen 1 vs the new Gen 2s
| The Following User Says Thank You to jflogerzi For This Useful Post: | autoracer86 (09-27-2024) |
#25 | |
Hell, I was conflicted about messing with the virgin connectors for the demo. "If it ain't broke..."
| The Following User Says Thank You to Ultramaroon For This Useful Post: | bcj (09-26-2024) |
#26 | |||
Drives: 2020 BRZ Sport Tech RS
"Note: 2017+ Models have some differences to earlier cars and will not run with the sample maps supplied in PCLink and the standard plug-in ecu hardware.
| The Following 3 Users Say Thank You to Tatsu333 For This Useful Post: |
#27 |
Ok folks, here's where we are. My FRS is on it's way to RS Motors, Inc. Ron is determined to fix the P0341 code problem. After fixing it, he will do a custom tune and ship the car back to me in Va. I'll post his findings and fixes.
I have a lot of admiration for Ron and his company. He is very invested in his customers and wants his products to be flawless. I have no doubt my car will be perfect when I get it back. |
| The Following 6 Users Say Thank You to blsfrs For This Useful Post: | makinen (11-17-2024), NoHaveMSG (11-14-2024), T-Steve (11-14-2024), Tatsu333 (11-18-2024), Ultramaroon (11-15-2024) |
#28 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (11-15-2024) |
| Another FA24 swap | blsfrs | Engine Swaps | 40 | 12-21-2024 11:59 AM |
| FA24 swap to a GT86 ? Anything I need be aware of? | twasd | Engine Swaps | 23 | 01-09-2024 11:28 PM |
| Viability of complete FA24 swap (motor and ECU)? | Tatsu333 | Engine Swaps | 43 | 02-18-2023 07:18 PM |
| P0341 Code being thrown on 2020 brz ts | bbearchell | Issues | Warranty | Recalls / TSB | 4 | 08-06-2022 06:42 PM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 11:55 AM |
