Old 08-24-2024, 02:35 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
P0341 code in my FA24 swap
Here's a snapshot of my intake cam's signals.
Number one looks erratic. Any idea why?
Old 08-24-2024, 05:45 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’d check the connections to the cam position sensor. Doesn’t RS use an adaptor?
Old 08-24-2024, 09:27 PM   #3
blsfrs
blsfrs's Avatar
RS uses a 2013-16 wiring harness and 2013 sensors. I couldn't see the coolant temp sensor but I'm guessing he either rethreaded a 2013-16 into the block or made a plug adaptor. Oil temp and pressure sensors are the old ones.
Tomorrow, I'm going to try a 0.0025 shim under the sensor. I was reading that if the air gap is to small there could be signal noise. Way back there was a recall where the dealers added a shim.
This article is for VR crank sensors but it should apply to cam sensors as well...I hope.
https://www.pistonheads.com/gassing/...&f=8&t=1814921
Old 08-25-2024, 03:17 PM   #4
blsfrs
blsfrs's Avatar
Things tried:
Switched intake sensors.
New sensor.
Replaced plug and rechecked continuity.
Ran engine with alternator unplugged.
Made 0.025 shim. Engine didn't want to start and then ran rough.
And, I've got this annoying accessory belt squeak. New Conti belt. Belt alignment looks a bit off. I used my 2013 alt bracket. I think I need a 22+.
Old 08-27-2024, 01:02 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Take another log of the signals with the 025 shim installed. Get some thin shim stock so you can stack layers to try to find the sweet spot. Having prior experience developing similar systems, I was disappointed to see how the early encoders were designed. Rookie mistake.
edit... I see now that you're logging the angle. That's a calculated value. I've also noticed a bit of what could be interpreted as either mechanical hysteresis or just too much derivative gain in the control loop of one of my servos. I don't think anyone has actually messed with the gains in the firmware so I've just ignored it and hope it doesn't end up in premature failure of that one phasor.
Old 08-27-2024, 09:51 PM   #6
blsfrs
blsfrs's Avatar
I'll try a thinner shim. The tsb bulletin (as I read it) indicates 1.26-1.35 mm. Without the shim, mine appeared closer, almost touching the trigger plate. With my shim, I was at about 1 mm.
Is there other data that I could log to give me a better idea what's going on? I stumbled on the cam angle because it showed the "aberration". Ecutek is not nube friendly.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://static.nhtsa.gov/odi/tsbs/2013/MC-10132237-9999.pdf
Old 08-28-2024, 04:04 PM   #7
Ultramaroon
not playing cards
That doc is a good read. Follow it over my intuition. None of this is noob-friendly. If I was in your shoes, I would finally break down and buy an oscilloscope. That's the perfect tool here. Check out the Subaru TSB for this same issue. They do it the "proper" way.
https://static.nhtsa.gov/odi/tsbs/20...89963-0699.pdf
Old 08-29-2024, 02:48 AM   #8
Ultramaroon
not playing cards
uh oh... I did it.
https://store.fhdm.xyz/dso-500k
Will be a fun experiment. No idea how long it will take to, or even if it will ship.
Old 08-29-2024, 09:01 AM   #9
blsfrs
blsfrs's Avatar
To paraphrase Dr McCoy: Dammit man, I'm a physical therapist, not an electronics genius.
Old 08-29-2024, 12:59 PM   #10
Ultramaroon
not playing cards
I accidentally ordered an extra one. They're coming from a Chinese outfit in Australia so who knows when I'll see them. My hope is to come up with a step-by-step tutorial for anyone interested. If it works, can't beat it for fifty bucks all in.
Old 08-30-2024, 02:54 PM   #11
alphasaur
friendly
Drives: 17' 86
eagerly following this thread in case I ever fa24 swap. Thanks for being a pioneer
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 08-30-2024, 03:55 PM   #12
blsfrs
blsfrs's Avatar
Thanks. I'm sure this P0341 problem is very atypical, but I've got a knack for atypical problems. Everything else has been really straight forward.
Later this weekend (just for giggles) I'm going to swap out the actuator. I may source another ecu just to rule it out.
Old 09-01-2024, 10:09 PM   #13
blsfrs
blsfrs's Avatar
I swapped the actuator, no change. Anybody got a spare ecu they want to sell?
Old 09-16-2024, 12:26 AM   #14
Ultramaroon
not playing cards
Meanwhile, over in Vantucky...
Look familiar? I forgot to order o-scope probes - DUH - so I could only monitor one channel with a ghetto setup. The real probes should arrive tomorrow.
Search this Thread:
Advanced Search
Another FA24 swap blsfrs Engine Swaps 40 12-21-2024 10:59 AM
FA24 swap to a GT86 ? Anything I need be aware of? twasd Engine Swaps 23 01-09-2024 10:28 PM
Viability of complete FA24 swap (motor and ECU)? Tatsu333 Engine Swaps 43 02-18-2023 06:18 PM
P0341 Code being thrown on 2020 brz ts bbearchell Issues | Warranty | Recalls / TSB 4 08-06-2022 05:42 PM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
