#15 |
Drives: 2013 frs red
Cams sticking?
#16 | |
Drives: Crapcan
I would think if it was an AVCS issue it would pop a code.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Rako (09-19-2022) |
#17 | |
Drives: 2013 frs base
#18 |
Drives: Crapcan
Not sure. I am not even entirely certain it’s not normal. It just looks odd to me.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (09-19-2022) |
#19 |
Drives: 2023 GR86 M/T
Yeah that's the thing, it looks normal for the most part..
#20 |
#21 |
#22 |
Drives: Toyota 86
There is a case that AVCS does not work but no code. It does not move even in the active testing in Techstream.
https://www.ft86club.com/forums/showthread.php?t=138803
| The Following User Says Thank You to makinen For This Useful Post: | NoHaveMSG (09-21-2022) |
#23 | |
#24 |
I just dropped my exhaust to check for restrictions just because I had a cat go bad once and thought debris might be stuck in the pipe but nothing there. Rode around with muffler disconnected and also nothing changed.
#25 |
Professional wrench
Drives: 2020 BRZ ST RS
I haven't read everything, so I hope its not a repeat.
I would put a different, mostly basic map. One that will work for your exhaust and intake for sure, but just a basic off the shelf map from the car.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
| The Following User Says Thank You to JohnH For This Useful Post: | Rako (11-28-2022) |
#26 |
UPDATE for anyone still interested
Flashed a stock 2017 ecutek map and I couldn't believe how much better the car ran. Even with the torque dip and all I have better acceleration and responsiveness and it's actually fun to drive again NOTE that I've ran 3 different tunes from 3 different reputable tuners (2 tuned it remotely and said everything looks fine) but all 3 have made my car run terrible before flashing the stock tune, which feels like an upgrade as crazy as it sounds. I'm positive the tunes aren't the problem and something else is f****** with me but what? What gives? I hope someone has a clue. |
#27 |
Drives: 17 Asphalt 86
Very odd. My car throttle feels significantly better tuned vs stock, along with overall powerband.
My tuner switched me over to a euro ROM when I tuned with ecutek. Cannot comment on the exact differences between USDM and EURO ROMs as I don't have the technical know-how. Dumbed down answer I was given is that it's less buggy. Maybe somebody can shed more light on the difference. @tomm.brz ? |
| The Following User Says Thank You to RToyo86 For This Useful Post: | Rako (11-28-2022) |
#28 |
Drives: brz 2017 hksv2
Bugs are related to racerom patch applied to >17 US oem map, so an unpatched rom as his doesn t have problem
i think it s case is that he just doesn t like the tunes he got from those tuners, and maybe the were not objectively well done oem tunes are very refined under 3000 rpm, and it s very much easy to mess up with smoothess and bogging down at low rpm if you don t spend time to improve it
| The Following User Says Thank You to tomm.brz For This Useful Post: | RToyo86 (11-28-2022) |
| any difference in power output between these two combinations of header+exhaust cats | giorgi0424 | Engine, Exhaust, Transmission | 20 | 03-22-2016 04:36 AM |
| power output oft tunes | denso | Software Tuning | 3 | 09-15-2015 07:53 AM |
| N/A power output potential as race setup? | rice_classic | Engine, Exhaust, Transmission | 67 | 12-17-2013 08:03 PM |
| 3rd gear inconsistent shifting | mike the snake | Issues | Warranty | Recalls / TSB | 30 | 11-22-2013 04:54 PM |
| Inconsistent gear box? | wootwoot | Engine, Exhaust, Transmission | 12 | 10-07-2013 03:15 PM |
