Old 03-21-2016, 08:30 PM   #1
giorgi0424
Drives: '14 SWP BRZ
any difference in power output between these two combinations of header+exhaust cats
so I already have a "catless" (it's a high-flow cat) catback on my BRZ, and since I want my car to be able to pass emissions/not throw engine lights, I'm forced to get a header with the cat in it still.
my question is, is there a difference in power gains and even sound with the different varieties of setups?
e.g. 1. header w/cat + catback with no cat
2. header w/o cat + catback with cat.
3. no cats on either (obviously i know this would yield highest hp gains and noise increase)
giorgi0424 is offline   Reply With Quote
Old 03-21-2016, 08:36 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
First things first:
- there are not "catback" exhaust systems with a cat. Catalytic converters are in the front pipe and header
- more power to be made w/ catless header
- catalytic converter in header is no guarantee of no check engine light
So power-wise, 3 > 2 > 1
Sound-wise, 3 > 1 or 2 depending on what front pipe and exhaust you have.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
giorgi0424 (03-21-2016)
Old 03-21-2016, 08:36 PM   #3
None of those combos will give you any more power without a tune to back them up. With the right tune for the setup they will all be so close that it doesn't matter much.
The sound differences however can be substantial. Less cats more noise.
Cole (03-21-2016), giorgi0424 (03-21-2016)
Old 03-21-2016, 08:40 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I noticed it says Southeastern PA in your location, would you happen to be near bucks county or philadelphia? If so the setup I have will most likely pass emissions at a local toyota dealership.
You can check here what emissions test you'll require:
http://www.ahs.dep.pa.gov/aq_apps/emissions/
For my case bucks county only requires Onboard Diagnostics and Gas Cap Check so a tune gets rid of the check engine light, and keeping the stock front pipe gets rid of most of the smell and makes it a bit less unfriendly to the environment.
Bottom line keep the front pipe cat, get a cat-less header from Gruppe or JDL will even out the torque dip the most and YOU MUST get a tune otherwise your throwing your money out the window because you're wasting fuel and any horsepower gains, and you'll fail emissions in PA in most counties because the ECU will throw out a P0420 code.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
giorgi0424 (03-21-2016), Tcoat (03-21-2016)
Old 03-21-2016, 08:42 PM   #5
giorgi0424
Drives: '14 SWP BRZ
Originally Posted by mav1178 View Post
First things first:
-alex
Yes, yes I know this. I was just being lazy... I have a Tsudo catback+frontpipe with a high-flow cat.
thank you for your input!
Old 03-21-2016, 08:43 PM   #6
giorgi0424
Drives: '14 SWP BRZ
right. but will there be a difference in noise if I only have 1 cat, and the location of that 1 cat? whether it's in the header or the frontpipe? or, will that too be marginal
Old 03-21-2016, 08:44 PM   #7
giorgi0424
Drives: '14 SWP BRZ
Originally Posted by FRSBRZGT86FAN View Post
I noticed it says Southeastern PA in your location, would you happen to be near bucks county or philadelphia? If so the setup I have passed emissions at a local toyota dealership.
Bottom line keep the front pipe cat, because removing the one in the header will even out the torque dip the most.
Yeah i live 25 min outside philly, in Delaware county. thanks for your input.
Old 03-21-2016, 08:47 PM   #8
FRSBRZGT86FAN
Yup, looks like you're in the same boat as me, gas cap and obd-II check, so you need to get a tune if you even have the slightest chance of passing. Also if the car is loud enough an inspector will look at the engine bay and notice a missing cat and heat shield and fail it regardless if they know this car well enough so be careful, the Tsudo system is quite loud if the car isn't obnoxiously loud, doesn't smell and doesn't throw codes techs won't bat an eyelid. Alternatively you can specifically go to a mom and pop sort of gas station to get emissions done, they'll be more lenient, or just put the stock header on for inspection the choice is yours
Old 03-21-2016, 08:48 PM   #9
giorgi0424
Drives: '14 SWP BRZ
sounds like i have to spend more $ than planned and replace the front-pipe with one that has a cat, and get a cat-less header. I need more moneys, lol
Old 03-21-2016, 08:49 PM   #10
giorgi0424
Drives: '14 SWP BRZ
Yup, looks like you're in the same boat as me, gas cap and obd-II check, so you need to get a tune if you even have the slightest chance of passing. Also if the car is loud enough an inspector will look at the engine bay and notice a missing cat if they know this car well enough so be careful, the Tsudo system is quite loud....
yes, it's quite loud! However, I'm fortunate to work at a dealership where I have technicians who would help me pass inspection
The Following User Says Thank You to giorgi0424 For This Useful Post:
FRSBRZGT86FAN (03-21-2016)
Old 03-21-2016, 08:51 PM   #11
mav1178
mav1178's Avatar
Having a cat is no guarantee of a quiet setup.
It's whether the catalytic converter functions as an effective resonator or not.
-alex
Tcoat (03-21-2016)
Old 03-21-2016, 08:51 PM   #12
FRSBRZGT86FAN
No issues then! You can get a Gruppe-S uel, overpipe, oil pan heatshield and gaskets for $610 and it's around $400 to get a used oft to get a nice stage 2 tune , put the stock front pipe back on and you won't regret it, however I warn you keeping the tsudo on will make it quite loud, the drone will probably be intense with any uel or EL header and that exhaust regardless of front pipe.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Tcoat (03-21-2016)
Old 03-21-2016, 08:52 PM   #13
The variables are huge. What type of what and all that. Not a question that can truly be answered with any form of accuracy.
FRSBRZGT86FAN (03-22-2016), giorgi0424 (03-21-2016)
Old 03-21-2016, 08:52 PM   #14
giorgi0424
Drives: '14 SWP BRZ
-alex
nope, not even looking for quietness, just the most effective setup outside of a cat-less system entirely!
cat, catback, exhaust, header, power
power output oft tunes denso Software Tuning 3 09-15-2015 06:53 AM
Exhaust combinations with 3" resonated catback Rican_D Engine, Exhaust, Transmission 11 05-06-2014 12:14 PM
Keeping factory cats with header? robtan Engine, Exhaust, Transmission 7 12-27-2013 03:40 PM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
Header and Exhaust Combinations TheseColorsDontRun Engine, Exhaust, Transmission 32 08-25-2013 05:29 PM
