Old 09-17-2022, 05:17 PM   #1
Rako
Drives: 2023 GR86 M/T
*SOLVED* Inconsistent power output
Hey all, I've tried many things and need help.
2017 BRZ manual performance package 45k miles
Catless plm header, srs over pipe, flex fuel kit
Most of the time the car runs like the symptoms below except maybe every 3 to 4 weeks, it'll run like a f****** dream for about 3 days and then it goes back to running like a disaster.
Symptoms/when the car runs like crap:
No CEL
Sluggish acceleration through out rpm band
Rough first gear start do to less responsive gas pedal
Revs drop noticeably quicker between shifts which makes shifts rough
Car sounds very raspy and louder than normal
When the car runs excellent:
Power and strong acceleration everywhere
(Even with the first engine start I can already tell it'll run great because it revs up stronger when I start it)
Gas pedal very responsive, first gear start like butter
Rev drop normal, smooth shifts
Car sounds clean and healthy, all you hear is the crisp rumble
What I've done:
new MAF
new upstream AF sensor
Checked back pressure for restriction (had a header cat collapse which made the front pipe cat collapse as well but all this was solved since then and the tune was updated for the current header)
Checked exhaust leaks, vacuum leaks
I've ran it on 3 different tunes, which were reviewed by the tuners who said everything's running like it should.
Coincidentally the last time it started running great all of a sudden was after I took out the air filter box to check vacuum leaks, I flipped the filter, put everything back and car ran good but no surprise to me, 3 to 4 days later, it's back to being a mess.
Weather doesn't seem to have and impact because it has ran great/awful in both high 90s and low 40s.
Any specific log would help?
Rako is offline   Reply With Quote
Old 09-17-2022, 07:56 PM   #2
humfrz
Bubba says to remove the air filter for a few miles and see how it runs.
The results just may lead you to the problem.
Old 09-17-2022, 10:04 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
really sounds like un-metered air is entering the motor somewhere, so the a/f ratio is getting thrown off
Old 09-17-2022, 11:29 PM   #4
Rako
haha I appreciate bubba but that doesn't seem safe
this one is when it runs bad
http://datazap.me/u/stix/2nd-gear-pu...?log=0&data=31
this one is when it runs good
Old 09-17-2022, 11:40 PM   #5
Rako
And yes vacuum leak was my main concern but I just can't find anything unless I'm missing something very small since there are no codes
Old 09-18-2022, 07:14 AM   #6
Ebush
Drives: 2017 Hot Lava 86
I had this same issue on my 2017 86 for nearly a year. I tried all kinds of things, even swapped out the throttle body for an aftermarket one. Then one day about a year ago I installed a K24 into the car and my throttle response has been great ever since. When it's not very responsive feeling, are you able to go full throttle and back to no throttle real quick without the engine revving, as If the pedal isn't registering? Mine would do that. For my car it was as if there was a half second delay on inputs with the pedal.
Ebush is offline   Reply With Quote
Old 09-18-2022, 08:14 AM   #7
StraightOuttaCanadaEh
Wes
those every 3-4 weeks you wouldn't happen to be disconnecting your battery, would you
Instagram: @gt86ws
Old 09-18-2022, 10:44 AM   #8
Rako
Yes I am able to do that, I think for me it has more to do with the power loss. Glad you got fixed it though
Old 09-18-2022, 10:44 AM   #9
Rako
No, definitely not
Old 09-18-2022, 11:22 AM   #10
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Are you running low on fuel when this happens? Like below 1/4 tank?
Old 09-18-2022, 12:39 PM   #11
Rako
No, it happens at all levels of fuel. E5 or 93 it doesn't matter
Old 09-18-2022, 02:06 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You need to log correct perimeters. There is not enough info in the logs to tell anything. Not sure if there is going to be anything to see being it is not tripping CEL. These are the funnest types of problems.
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
Ignition Advance / Total Timing (degrees)
AFR
Commanded AFR
LTFT
Oil Temp
Fuel Sys Status
IAT
IAM Advance Multiplier
FLKC
Old 09-18-2022, 05:08 PM   #13
Rako
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
AFR
Commanded AFR
LTFT
Oil Temp
Fuel Sys Status
IAT
FLKC
Ok thanks I'll have these logs ready tonight
Old 09-18-2022, 06:56 PM   #14
Rako
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
AFR
Commanded AFR
LTFT
Oil Temp
Fuel Sys Status
IAT
FLKC
new logs
warm idle
http://datazap.me/u/stix/warm-idle?log=0&data=4
normal driving
http://datazap.me/u/stix/normal-driving?log=0&data=4
any difference in power output between these two combinations of header+exhaust cats giorgi0424 Engine, Exhaust, Transmission 20 03-22-2016 03:36 AM
power output oft tunes denso Software Tuning 3 09-15-2015 06:53 AM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
3rd gear inconsistent shifting mike the snake Issues | Warranty | Recalls / TSB 30 11-22-2013 03:54 PM
Inconsistent gear box? wootwoot Engine, Exhaust, Transmission 12 10-07-2013 02:15 PM
