Old 07-15-2022, 08:40 PM   #1
Sovereign
Legend
Drives: Whiteout FR-S
Scratchy Noise and Peddle vibration
Solved: Dented passenger side sway bar bracket
Background:
Hey guys, so I just recently hit a pretty decent sized rock and it sounded bad. I checked to see if anything fell off or broke but I did not see anything wrong in the engine bay and nothing hanging underneath the car.
Issue:
Now when I step on the throttle from standstill I hear a weird scratchy/sandy noise like something is dragging and a weird vibration on the gas peddle for a second or 2 then no vibration and sound. This was not there until I hit the rock. When I do a gentle start nothing vibrates or makes noise only when I do a harder start I hear and feel it. If I WOT while already moving the issue is not there and nothing while revving in neutral either. Any thoughts?
Specs:
2014 frs Mods: full exhaust, aftermarket wheels
Sovereign is offline   Reply With Quote
Old 07-15-2022, 09:48 PM   #2
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
sounds to me like you damaged either the driveshaft or one of the axles. Also it could be that you damaged a brake backing plate and its touching the rotor, but being that you say it happens when you get on the gas, I would be looking at the driveshaft or one of the rear axles. Just a guess, but its based in logic
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following User Says Thank You to JohnH For This Useful Post:
Sovereign (07-15-2022)
Old 07-15-2022, 10:58 PM   #3
Sovereign
Legend
It also sounded like glass breaking (might be hearing things) too but no visible glass is broken and nothing leaking either. But what you say makes sense might have to go to a shop. I went under my car today to look if any heat shielding might be rattling but nothing. Thank you
Old 07-16-2022, 05:41 PM   #4
I'd guess that something (like a heat shield or under panel) came lose or got bent by the rock. Maybe it only "hits" when the engine is torquing over.
I'd suggest you get your car up on a rack and look for something that may be hitting when the engine moves in the torquing position.
Bubba says to take a crowbar and bend away anything that looks like it might be touching something else -
Sovereign (07-18-2022)
Old 07-16-2022, 06:19 PM   #5
pedal
Old 07-18-2022, 03:38 PM   #6
Sovereign
Legend
@humfrz and @JohnH so it turns out I dented the passenger side sway bar bracket. Thanks for the responses for possible issues.
The Following 3 Users Say Thank You to Sovereign For This Useful Post:
Decep (07-19-2022), humfrz (07-18-2022), JohnH (07-19-2022)
Old 07-19-2022, 05:31 PM   #7
Decep
Drives: 2013 FR-S Series 10
pedal
Begone. Peddle your spelling corrections elsewhere!
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Ultramaroon (07-19-2022)
Old 07-19-2022, 05:36 PM   #8
JohnH
Professional wrench
front or rear? and what was it touching?
225/45VR17 RT660s
Off-throttle vibration and steering noise alex87f Issues | Warranty | Recalls / TSB 4 06-19-2018 06:00 PM
Diff vibration/noise on decel Im_SPEED Engine, Exhaust, Transmission 9 01-28-2017 09:18 PM
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 02:42 PM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 08:42 AM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 10:15 AM
