Old 01-27-2017, 06:34 PM   #1
Im_SPEED
Drives: FRS hot lava
Diff vibration/noise on decel
see if anyone has any advice. a little back round info. Im running a OSG LSD in an M85 housing using 3.73 gears also white lines diff bushings and DSS axles (noise was happening before axles) ,the side bearings are new like 3k on them the diff had 43k out of a wreaked Lexus. using OSG fluid.
so when i let off the throttle in 5th there is a noise coming from the diff like vibration or a hum. but its only in 5th and only on when you let off the throttle. doesn't do it any other time.
Im_SPEED is offline   Reply With Quote
Old 01-27-2017, 06:42 PM   #2
gramicci101
Off Topic
Could it be happening in other gears and you're just not hearing it? If it's all the gears, maybe the backlash is off. If it's just 5th, that would make me think it's a transmission gear issue, since that's the only place where 5th limits movement to a specific set of gears.
Old 01-27-2017, 07:23 PM   #3
Im_SPEED
im fairly certain its only in 5th. cant be 100%. that is the part the is confusing me.i thought it might be a transmission issue but it started right after i did the diff and engine mounts. backlash should be good i checked it before i installed and the pinion depth never changed.
Old 01-27-2017, 07:36 PM   #4
gramicci101
Off Topic
The diff outrigger bushings definitely amplify gear whine a bit, so that's probably it. I get it in 1st and 2nd when I coast in gear at low speeds. Otherwise my radio is too loud for me to hear it anyways. Some people leave the back bushings on and remove the front outrigger bushings; they say that seems to help. I just live with it, because it isn't really annoying to me.
Old 01-27-2017, 09:03 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Its your bushings and mounts, forget you think you even have a problem.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-28-2017, 06:06 PM   #6
Im_SPEED
If it's normal why only in 5th ? My only thinking is it has something to do with it being 1 to 1 ratio
Old 01-28-2017, 07:24 PM   #7
FRS Justin
Drives: 2013 Asphalt FRS
I would look at the trans not the diff if the only time it does it is in 5th. also you might want to try swapping diffs back to make sure its the diff.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 01-28-2017, 08:03 PM   #8
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
I bet it's the whitline diff bushings...mine make similar noises in 5th.
skylinekin is offline   Reply With Quote
Old 01-28-2017, 08:17 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1
The midshaft does not have its own thrust bearings. It relies on a balance of opposing axial forces between the input and output gear pairs.
If either of the end bearings is shot, I can picture the midshaft rattling around in fifth gear while it's unloaded.
Credit to @VeloxEric for sharing his experience.
FRS Justin (01-28-2017), VerusEric (01-28-2017)
Old 01-28-2017, 09:18 PM   #10
Im_SPEED
+1
That makes sence I figured my transmission will not last me through this season of racing anyway. So I will find out one way or another.
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
Diff noise issues fuddbutter Engine, Exhaust, Transmission 7 10-10-2015 07:50 AM
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 02:42 PM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 08:42 AM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 10:15 AM
