Old 06-08-2014, 04:24 PM   #1
Pcharliep04
Drives: Fr-s
trd quick shifter ? vibration noise
i got the trd quick shifter , it just recently started making a low vibration noise when it is in gear . when in neutral no noise while driving in all gears small vibration noise i move it a little while in gear and stop and i let it go back to it original position and vibration noise ???
Pcharliep04 is offline   Reply With Quote
Old 06-09-2014, 09:48 AM   #2
nadbrz
Learnin a little everyday
Drives: '13 Crystal Black Silica BRZ
I had the same issue whenever the shifter is in 1st gear. I later noticed that the noise is coming from shift boot (faux leather) being rubbed. Nothing to worry i guess.
nadbrz is offline   Reply With Quote
Old 06-09-2014, 11:08 AM   #3
suaveflooder
could it be the bushing on the shifter (where it connects to the arm coming from the transmission) itself being harder? I'm actually asking because I didn't check my stock one, and from what I remember I had noise (although not as loud) with my stock shifter as well.
suaveflooder is offline   Reply With Quote
Old 06-11-2014, 07:59 AM   #4
Pcharliep04
Drives: Fr-s
So u have the trd quick shifter doing the same noise
Old 07-30-2014, 11:54 PM   #5
Nu_era
Drives: 13 FRS 10series/94 Supra Turbo 6spd
I have it. It keeps getting worse. Now I can't shift into second gear correctly. Better not be the damn shifter.
2013 Scion FR-S "10" series 6-speed Manual- Daily Driver
2006 Lexus 400H - Family Car
1994 Toyota Supra Single Turbo 6-speed- Weekend Driver
www.affordablewindowtinting.com<---- My services
Nu_era is offline   Reply With Quote
Old 08-01-2014, 02:42 PM   #6
tomkozski
Drives: 2017 WRB BRZ w/ PP
Check to make sure everything is torqued to spec. It's possible that the bolts might have loosened up a bit after install.
tomkozski is offline   Reply With Quote
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 08:42 AM
trd quick shifter? tjohnson104 Engine, Exhaust, Transmission 6 01-26-2014 02:37 PM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 10:15 AM
