Old 09-07-2013, 10:33 PM   #1
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Vibration/Noise when clutch is depressed
2013 Scion FR-S
31,000 KM Lots of stop and go city, and highway driving...
Driving style is agressive, but havent done much clutch kicking or hard launching.
I tried searching but couldn't find this exact issue on the forum, but it seems similar to what other people describe as a loose release bearing.
So when i fully depress the clutch pedal in neutral, or in any gear there is a mild vibration and what sounds like a rattle/squeek noise. It sounds like a bearing is loose or worn- but i honestly have no idea.
Has anyone else had this problem? Or know what the problem is? and/or know if it would be covered under warranty?
Thanks in advance guys!
Ravenlokk is offline   Reply With Quote
Old 09-15-2013, 06:55 AM   #2
Jefffrs
Jefffrs's Avatar
Drives: FR-S Turbo 10 Series
I have the same problem. Need help too!
Jefffrs is offline   Reply With Quote
Old 09-15-2013, 06:37 PM   #3
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
shouldnt really matter if it's capable to being fixed under warranty where as it "should" be repalced and/or fixed under warranty i would agree with you that there is something wrong if you really are hearing that kind of noise and should take it in to be looked at.
alex_86 is offline   Reply With Quote
Old 09-15-2013, 07:10 PM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
I just got the same exact issue today, but on my aftermarket clutch. Wtf is going on here? Any solutions?
Old 09-15-2013, 08:11 PM   #5
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Sounds like a throw out bearing .
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 09-15-2013, 08:21 PM   #6
Synack
Boosted
Synack's Avatar
Drives: Sideways
Even if it is, what's to prevent it from screwing up again after replacing it?
Old 09-15-2013, 08:24 PM   #7
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Post a sound clip of it
Young_makaveli is offline   Reply With Quote
Old 09-15-2013, 09:32 PM   #8
Wo6M
Wo6M's Avatar
A new one would do the trick lol I mean unless you have a upgraded bearing we wont have much of a choice....
Mods:
Old 09-15-2013, 11:41 PM   #9
Synack
Boosted
Synack's Avatar
Drives: Sideways
That would be preferable. I mean I've got a badass clutch, I hate being subjected to the other weaker parts of the chain. I need to open up my tranny anyway, my shifting has been god awful lately. For some reason it's been acting like the clutch is only getting pressed in 90% of the way, which barely allows for shifting.
Old 09-16-2013, 12:31 AM   #10
Wo6M
Wo6M's Avatar
Perhaps the clutch cylinder needs to be looked at ? Or the diaphragm of the clutch plate somehow was not aligned correctly?
I'm just giving humble opinion. @Synack
Mods:
Old 09-16-2013, 12:41 AM   #11
humfrz
Yep, I agree with Wo6M.
The clutch throw out bearing is the most likely the bad actor.
However, unless it was just a bad bearing, something else (like a bent fork) may have made it go bad.
An "operation" is in order ....
humfrz
Old 09-16-2013, 09:18 AM   #12
Mikem53
Drives: FR-S 6MT
The throw out bearing comes into play when you depress the clutch..
Might be worn or damaged if you get constant noise which the clutch depressed.
Some noise is considered normal.. But it should not be loud or excessive...
Mikem53 is offline   Reply With Quote
Old 09-16-2013, 12:11 PM   #13
Synack
Boosted
Synack's Avatar
Drives: Sideways
humfrz
Time to rip it apart. I wish an aftermarket tranny existed.
Old 09-17-2013, 12:28 AM   #14
humfrz
Well, I hope you get it fixed up soon.
Back in the day, it wasn't uncommon for a throw out bearing to go bad, especially if the driver rode the clutch or the clutch was badly out of adjustment. Not so much anymore.
Keep us posted on what you find.
humfrz
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 08:42 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
Winding Noise From Clutch Bach415 Northern California 0 06-24-2013 07:19 PM
