Old 06-10-2022, 10:37 AM   #1
Koba
Drives: 2020 BRZ
Oil Temp and Pressure Sender Location?
Engine block or oil cooler sandwich plate? Which gives the most accurate reading?
Thank you.
Koba is offline   Reply With Quote
Old 06-10-2022, 10:50 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Consistency is what I'd focus on, rather than looking for "most accurate" to be honest. Find the norm ranges and be cognizant of them, so if there is a time it's out of that norm, you can know something changed
Old 06-10-2022, 01:28 PM   #3
KillerBMotorsport
KillerBMotorsport's Avatar
Temp = Sump
Pressure = OEM Switch Location (timing cover)
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
timurrrr (06-12-2022)
Old 06-11-2022, 06:10 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I take my temp and pressure from the sandwich plate. I "remote mounted" my pressure sensor with a 12" braided line. Jackson Racing makes fittings for their sandwich plate. While I agree that sump temp may be more accurate, most of us just need to know when things are going south in a very bad way.
Old 06-12-2022, 06:05 AM   #5
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I’m trying the ‘Glowshift 1/8 BSPT GT86 Sensor Thread Adapter’.
It installed simply and the Innovate temp and pressure sensors threaded in perfectly along with the OEM pressure sensor it displaces.
No readings yet. I’m just mid-install of the gauge package.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 06-12-2022, 07:44 PM   #6
KillerBMotorsport
How about this...
Old 06-13-2022, 04:00 PM   #7
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
That's a whole lotta meat hanging off a small brass fitting. Any reliability issues with that? I'm not saying no, but my spidy senses are tingling.
Matt93SE is offline   Reply With Quote
The Following User Says Thank You to Matt93SE For This Useful Post:
DocWalt (06-17-2022)
Old 06-13-2022, 05:34 PM   #8
KillerBMotorsport
Good thing it's not brass
We've been selling these since 2014 without a single issue.
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
Matt93SE (06-14-2022), RT-BRZ (06-14-2022)
Old 06-14-2022, 07:17 AM   #9
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by KillerBMotorsport View Post
Temp = Sump
Do you happen to know what the disparity is between the timing cover, and the top of the block by the TB?
Old 06-14-2022, 08:43 AM   #10
Matt93SE
good call. First time I opened the post, the second image didn't load, and the top one was thumbnail size. I assumed by the color of the threads that the fitting was brass. stupid interweb is playing tricks on me.
KillerBMotorsport (06-14-2022)
Old 06-14-2022, 01:45 PM   #11
KillerBMotorsport
For pressure?
Old 06-14-2022, 02:06 PM   #12
dragoontwo
dragoontwo's Avatar
For pressure?
Yes.
Old 06-14-2022, 10:04 PM   #13
KillerBMotorsport
Yes.
I don't. I'll look at the block tomorrow to verify, but IIRC that location is after the passages split, which would show a pressure drop vs at the outlet of the pump (timing cover). Definitely recommend as close to the outlet of the pump as possible.
dragoontwo (06-15-2022)
Old 06-15-2022, 06:48 AM   #14
dragoontwo
dragoontwo's Avatar
I wonder if that's why I'm seeing pressure fluctuations at 2 RPM ranges under steady state cruising.
DIY - Oil pressure sender and gauge (Auberins) Trap63 DIY (Do-It-Yourself) Guides 15 09-03-2021 12:48 AM
Oil pressure sender IsaiahW BRZ First-Gen (2012+) — General Topics 12 04-10-2021 04:26 PM
Removing OEM Oil Temp/Pressure sender Bodalenko DIY (Do-It-Yourself) Guides 6 11-30-2017 03:32 PM
Oil pressure sender thread size lbroskee Engine, Exhaust, Transmission 8 10-29-2015 11:56 PM
