Drives: 2020 BRZ
Oil Temp and Pressure Sender Location?
Engine block or oil cooler sandwich plate? Which gives the most accurate reading?
Thank you. |
#2 |
Rust bucket enthusiast
Consistency is what I'd focus on, rather than looking for "most accurate" to be honest. Find the norm ranges and be cognizant of them, so if there is a time it's out of that norm, you can know something changed
#3 |
Temp = Sump
Pressure = OEM Switch Location (timing cover) |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | timurrrr (06-12-2022) |
#4 |
Drives: 2013 frs base
I take my temp and pressure from the sandwich plate. I "remote mounted" my pressure sensor with a 12" braided line. Jackson Racing makes fittings for their sandwich plate. While I agree that sump temp may be more accurate, most of us just need to know when things are going south in a very bad way.
#5 |
Drives: 2016 Scion FRS Release Series 2#439
I’m trying the ‘Glowshift 1/8 BSPT GT86 Sensor Thread Adapter’.
It installed simply and the Innovate temp and pressure sensors threaded in perfectly along with the OEM pressure sensor it displaces. No readings yet. I’m just mid-install of the gauge package.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#6 |
How about this...
#7 |
Drives: 2013 FR-S, 2017 BRZ
That's a whole lotta meat hanging off a small brass fitting. Any reliability issues with that? I'm not saying no, but my spidy senses are tingling.
| The Following User Says Thank You to Matt93SE For This Useful Post: | DocWalt (06-17-2022) |
#8 |
#9 |
Drives: 22 BRZ limited
#10 | |
| The Following User Says Thank You to Matt93SE For This Useful Post: | KillerBMotorsport (06-14-2022) |
#11 |
#12 |
#13 |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | dragoontwo (06-15-2022) |
#14 |
I wonder if that's why I'm seeing pressure fluctuations at 2 RPM ranges under steady state cruising.
| DIY - Oil pressure sender and gauge (Auberins) | Trap63 | DIY (Do-It-Yourself) Guides | 15 | 09-03-2021 12:48 AM |
| Oil pressure sender | IsaiahW | BRZ First-Gen (2012+) — General Topics | 12 | 04-10-2021 04:26 PM |
| Removing OEM Oil Temp/Pressure sender | Bodalenko | DIY (Do-It-Yourself) Guides | 6 | 11-30-2017 03:32 PM |
| Oil pressure sender thread size | lbroskee | Engine, Exhaust, Transmission | 8 | 10-29-2015 11:56 PM |
