Old 02-14-2015, 11:39 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Smile DIY - Oil pressure sender and gauge (Auberins)
This is my job to install a smart gauge for oil pressure, very accurate and small. Wide alarm functions. Buzzer fitting too (opt).
Box it's a 1/32 DIN 22x45 mm and it fits very well inside "Push button start" box. You need to cut inner back . I mounted and fixed it with two plastic screws coming from two little clips (hot soldered).
About sender, you need unplug the cap near air intake throttle. You need a big torque as it is white loctite plugged.
Included wiring in combo is 3 ft (1 mt) and you need reach 2.50/2.60 mt . Max cable length admitted is 3 mt (9 ft)
From Auberins you need:
www.auberins.com/index.php?main_pag...products_id=226
http://www.auberins.com/index.php?ma...roducts_id=226
SYL1813 A (A is amber)
10 Bar (150 PSI) pressure sender P210
The combo includes sender, wiring and gauge, $89,95
To install the sender you need an adapter : M18x1,5 - 1/8 27 NPT
Some shoots
Inside the SYL1813A (make holes for air vent)
Follow included Auberins directions to setup (Bar or PSI) and for removing SYL1813 box for soldering it with plastic nuts.
Trap63 is offline   Reply With Quote
The Following 8 Users Say Thank You to Trap63 For This Useful Post:
afx (02-16-2015), chaoskaze (11-01-2017), GhostOp86 (05-02-2015), Guillaume (02-17-2015), Joesurf79 (11-19-2017), jrhudson (09-03-2021), MJones_RB (09-03-2021), ripper (02-17-2015)
Old 02-17-2015, 08:39 AM   #2
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Neat setup, I will follow that route if I decide to get an oil pressure gauge! Thanks for sharing.
The Following User Says Thank You to Guillaume For This Useful Post:
Trap63 (02-17-2015)
Old 02-17-2015, 10:56 AM   #3
Trap63
Trap63's Avatar
In conjunction with Torque Pro on Android HU or HKS OB link you can see all parameters you need while racing. Auberins SYL1813 can send a signal to open or close adding fan for oilcooler, too. Very impressive and amazing for maintaining a stock look of internal design. I hate all "tuning" gauges....mostly in the wrong place.
The Following User Says Thank You to Trap63 For This Useful Post:
Old 05-01-2015, 08:19 PM   #4
Max FRS
Drives: 2015 Halo FRS Automatic
Where did you get the adapters to install the sensor?
Max
Max FRS is offline   Reply With Quote
Old 05-02-2015, 05:34 AM   #5
Trap63
Trap63's Avatar
Max
I bought on Ebay, UK.
http://www.ebay.it/itm/LMA-Racing-Mo...item46195c308d
Guillaume (05-02-2015)
Old 05-02-2015, 09:06 PM   #6
Max FRS
Thanks, just ordered one.
Max
Old 05-05-2015, 09:56 AM   #7
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
You can get the adapter at FastWRX too: http://www.fastwrx.com/products/oil-gallery-plug
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
Trap63 (11-20-2017)
Old 08-03-2015, 12:44 PM   #8
pleong
Drives: 2013 Whiteout FR-S
is there an alternative place to put the sensor? I was wanting to use this spot for an oil accumulator.
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 08-19-2021, 06:23 PM   #9
fatboydean
Drives: 2016 BRZ Hikari
which LED color you chose? Red or Amber? I saw on the pic the 'red' box is checked...
fatboydean is offline   Reply With Quote
Old 08-21-2021, 09:16 AM   #10
Trap63
Trap63's Avatar
amber
Old 08-22-2021, 03:35 PM   #11
fatboydean
thanks for the reply, I wonder how you deal with the wire lenth? just cut in the middle and add extension cords?
Old 08-22-2021, 03:39 PM   #12
Trap63
Trap63's Avatar
you need an extension wire about 40 cm, no signal degradation is evaluable, respect wire section and solder it. Preferably to join not in engine bay.
fatboydean (08-23-2021)
Old 09-03-2021, 12:55 AM   #13
fatboydean
one more question, you do need to have 12V supply for this unit in addition to the 3 sensor wires right?
Old 09-03-2021, 01:20 AM   #14
Trap63
Trap63's Avatar
yes, it is. ACC+ is the solution.
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 01:48 PM
Oil Pressure Observations - Anyone else using a gauge? Dave-ROR Engine, Exhaust, Transmission 29 01-20-2014 01:56 AM
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 07:09 PM
Oil Pressure Sender Unit Fitment Question Captain Snooze Engine, Exhaust, Transmission 2 07-06-2013 01:41 AM
