-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Oil Temp and Pressure Sender Location? (https://www.ft86club.com/forums/showthread.php?t=150062)
Koba 06-10-2022 10:37 AM
Engine block or oil cooler sandwich plate? Which gives the most accurate reading?
Thank you.
DarkPira7e 06-10-2022 10:50 AM
Consistency is what I'd focus on, rather than looking for "most accurate" to be honest. Find the norm ranges and be cognizant of them, so if there is a time it's out of that norm, you can know something changed
KillerBMotorsport 06-10-2022 01:28 PM
Temp = Sump
Pressure = OEM Switch Location (timing cover)
blsfrs 06-11-2022 06:10 PM
I take my temp and pressure from the sandwich plate. I "remote mounted" my pressure sensor with a 12" braided line. Jackson Racing makes fittings for their sandwich plate. While I agree that sump temp may be more accurate, most of us just need to know when things are going south in a very bad way.
Muskoka800 06-12-2022 06:05 AM
I’m trying the ‘Glowshift 1/8 BSPT GT86 Sensor Thread Adapter’.
It installed simply and the Innovate temp and pressure sensors threaded in perfectly along with the OEM pressure sensor it displaces.
No readings yet. I’m just mid-install of the gauge package.
KillerBMotorsport 06-12-2022 07:44 PM
How about this...
https://killerbmotorsports.sharepoin...q7DlQ?e=Z7c6ax
https://killerbmotorsports.sharepoin...kBR1w?e=YeOr2Z
Matt93SE 06-13-2022 04:00 PM
That's a whole lotta meat hanging off a small brass fitting. Any reliability issues with that? I'm not saying no, but my spidy senses are tingling.
KillerBMotorsport 06-13-2022 05:34 PM
Good thing it's not brass ;)
We've been selling these since 2014 without a single issue.
dragoontwo 06-14-2022 07:17 AM
Originally Posted by KillerBMotorsport (Post 3528632)
Temp = Sump
Do you happen to know what the disparity is between the timing cover, and the top of the block by the TB?
Matt93SE 06-14-2022 08:43 AM
good call. First time I opened the post, the second image didn't load, and the top one was thumbnail size. I assumed by the color of the threads that the fitting was brass. stupid interweb is playing tricks on me. :)
KillerBMotorsport 06-14-2022 01:45 PM
For pressure?
dragoontwo 06-14-2022 02:06 PM
Originally Posted by KillerBMotorsport (Post 3529212)
For pressure?
Yes.
KillerBMotorsport 06-14-2022 10:04 PM
Originally Posted by dragoontwo (Post 3529216)
Yes.
I don't. I'll look at the block tomorrow to verify, but IIRC that location is after the passages split, which would show a pressure drop vs at the outlet of the pump (timing cover). Definitely recommend as close to the outlet of the pump as possible.
dragoontwo 06-15-2022 06:48 AM
I wonder if that's why I'm seeing pressure fluctuations at 2 RPM ranges under steady state cruising.
