Old 04-03-2021, 05:37 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Oil pressure sender
Engine was running decent after its first start up from a rebuild but notice oil pressure dropping dramatically so stopped engine and my damn oil pressure sensor is pouring from the threads Not leaking, POURING. I then replaced the sensor and that didn’t help. I did take the sensor off when i got the timing cover cleaned i may have over tightened and damaged thread size. any solutions? I do have pressures gauges
IsaiahW is offline   Reply With Quote
Old 04-03-2021, 06:07 PM   #2
Grady
Grady's Avatar
Over-torqued and cracked?
Old 04-03-2021, 10:02 PM   #3
IsaiahW
IsaiahW's Avatar
Oil pressure sender
Yup after inspecting closely it appears i have a crack i literally just got this engine rebuilt i dont think this is fixable so a couple qts of expensive breakin oil wasted
Old 04-04-2021, 10:33 AM   #4
Grady
Grady's Avatar
Well that sucks! Where is HUMFRS? I bet Buba is going to recommend som JB weld.
Old 04-04-2021, 12:42 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have a spare timing cover I was going to use for a project you can have for free, just pay shipping. PM me if you want it.
The Following 10 Users Say Thank You to NoHaveMSG For This Useful Post:
Bonburner (04-04-2021), BrahmaBull1990 (04-10-2021), Capt Spaulding (04-04-2021), CrowsFeast (04-06-2021), HKz (04-14-2021), IsaiahW (04-04-2021), Tcoat (04-10-2021), timurrrr (04-08-2021), tintumz22 (04-05-2021), Ultramaroon (04-04-2021)
Old 04-04-2021, 07:59 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Nooooooo!
Old 04-04-2021, 10:15 PM   #7
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
This community rocks
Old 04-06-2021, 10:16 AM   #8
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Loving the MCB mentality
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
NoHaveMSG (04-07-2021)
Old 04-08-2021, 12:40 PM   #9
pope
has a funny hat
Drives: 2014 BRZ Limited
Done well, this can actually work. Fixed a coolant sensor port on a salvage yard cobra intake this way.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
Ultramaroon (04-10-2021)
Old 04-10-2021, 02:48 AM   #10
Ultramaroon
not playing cards
+1 I was shocked when a buddy fixed a cracked iron block with it. Lasted at least a year. Then I moved away. Lost track.
Old 04-10-2021, 10:13 AM   #11
I will jump on this bandwagon as well. If done properly it means taking it off, cleaning the living hell outta it, applying exactly the right amount to fill the crack, tapping the thread and reinstalling it.
So at that point you may as well just replace it. Especially when a free one is offered up!
NoHaveMSG (04-10-2021), Ultramaroon (04-10-2021)
Old 04-10-2021, 03:51 PM   #12
Ultramaroon
not playing cards
Amen to all of the above. I'll review for the record. This is without judgement. We've all learned lessons the hard way.
OP either wasn't aware of, or greatly underestimated the wedging action of a tapered thread. The temp sensor was also way over-torqued. We can see that it's bottomed out. There are torque values published for these fittings but in reality, they only need to be tightened until there's a smidge of resistance. The thread sealant will do the rest. If the threads are in good shape, and are clean, might even get away with skipping the sealant.
Most service-related damage comes from over-torquing or cross-threading fasteners. Even "experienced" mechanics rarely appreciate how much care it takes to reuse threaded joints without damaging them. This is especially true for steel screws in soft aluminum.
Old 04-10-2021, 04:26 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Two actually. OP ended up getting another one for free locally. At least my spare is now nicely packaged for storage now
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Tcoat (04-10-2021)
DIY - Oil pressure sender and gauge (Auberins) Trap63 DIY (Do-It-Yourself) Guides 15 09-03-2021 12:48 AM
Removing OEM Oil Temp/Pressure sender Bodalenko DIY (Do-It-Yourself) Guides 6 11-30-2017 03:32 PM
-=-=SOLD-=-=- AEM Fuel Pressure Gauge+Sender Ivegotamain2 Interior Parts (Incl. Lighting) 0 09-29-2016 11:38 AM
Oil pressure sender thread size lbroskee Engine, Exhaust, Transmission 8 10-29-2015 11:56 PM
Oil Pressure Sender Unit Fitment Question Captain Snooze Engine, Exhaust, Transmission 2 07-06-2013 12:41 AM
