#15 |
86 Challenge
Drives: 2017 BRZ
Tracked with the forester oil cooler and stock engine on Thunderhill, Sonoma, and Laguna Seca; oil temps still hit 270F according to the cluster. Not enough for track use.
| The Following User Says Thank You to mkodama For This Useful Post: | treedodger (01-15-2019) |
#16 |
Drives: BRZ 2018
#17 |
Drives: 2014 FR-S SSC
Real world data point:
I have the OEM cooler hooked up to the throttle body Just got back from Barber in AL where the days were 50ºF and overcast. Your typical header/91 tune car. I could do the entire 20-25 min sessions and the oil temp stabilized right around 245ºF. Never exceeded 250ºF. Over the summer, I got 5 laps of a 2 mile circuit when it was 80ºF before temps climbed above 250ºF and i did a cool down lap and then 2 more laps before hitting 250ºF again. It works to some extent. Will not keep you going 20 min on a hot summer day.
-Eric K - Milwaukee Region SCCA - 2014 FR-S
| The Following 5 Users Say Thank You to snoxracer183 For This Useful Post: | dpaqu (05-15-2019), jflogerzi (01-16-2019), justint5387 (01-17-2019), nico_rsx (01-18-2019), SuperTom (04-05-2022) |
#18 |
Drives: 2020 Hakone 86
reviving this thread since I don't feel like starting a new one of the same topic. I live roughly 30 miles from death valley and see ambient temps as high as 120F. I'm trying to figure out the right oil cooler to pick up. I'm NA and mostly drive it hard on the nearby mountain roads where I regularly see temps of 270F+ if I'm not careful. will I be fine running the forester cooler + 5w-30 or should I look into a air-based cooler?
#19 | |
Drives: 17 Asphalt 86
It doesn't do a ton once it heat soaks but I find it will bring temps down faster once you do a cool down compared to no cooler A friend who tracks his the the cooler and 5w-30 at Calabogie mentioned peak temps dropped from 290 to 270 peak. No where near what a air to oil cooler will do. |
#20 | |
Jackson Racing bare minimum, GReddy, ideally. PM me to order. |
#21 | |
2013 Series 10 FRS #553
#22 |
Just curious, is anyone using the Jackson combo oil cooler radiator, and if so how well does it work and under what conditions/mod level?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
#23 |
see sig for specs/setup. For NA it works great even in hot Socal Summer months. For boosted cars it might struggle a bit as its not as good as a stand alone.
#24 | |
I'll post back after I get some track time. My oil temps hit 290F during a track day last year which prompted me to look into cooling options. I can see this being the case as an air/air oil cooler will likely be much more efficient, plus, it'd be easier to size-up to a larger core if needed. However, I see the JR DROC as being probably the best option for dual-purpose cars. You get the benefit of cooler oil temps during track days and faster oil warm-up during winter. |
#25 |
At the track
Drives: '14 FRS - Former e92 M3
Spend the money on the Greddy cooler… Drove my car in 100+ degree weather at Cota on Hoosiers in July in a Time Trial. Oil temp never went above 230, happy to provide Aim data.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
| The Following User Says Thank You to Kelse92 For This Useful Post: | SCFD (04-15-2022) |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| FS: Oil Cooler - Forester XT Setup | kamikaze7 | Canada Classifieds | 4 | 08-21-2016 09:15 AM |
| NED Forester OEM oil cooler kit | ryoma | Engine, Exhaust, Transmission | 2 | 04-20-2015 07:16 PM |
| FS: used forester oem diy oil cooler | cruizin01 | Engine, Exhaust, Bolt-Ons | 2 | 01-05-2015 04:12 AM |
