Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-25-2022, 01:41 PM   #1
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Jacking location for lifting the whole side of the car
I'm trying to rotate my tires soon and I don't have a spare tire to swap around so I need to jack up two front and back wheels to rotate them.
On my Miata, you could use a jack pad and jack the car from underneath the mirror. This would jack up the whole side of the car and you could put a couple of jack stands under the pinch welds to hold the side of the car up.
Can I do this with the BRZ too? Or should I jack it up from elsewhere?
Interceptor777 is offline   Reply With Quote
Old 03-25-2022, 02:10 PM   #2
kaesu
Drives: 22 BRZ
There are two jacking points: one in the front and rear. The rear is the differential, and the this part of the frame where theres a little bump extruding from it. I think there's a picture in the manual
kaesu is offline   Reply With Quote
The Following User Says Thank You to kaesu For This Useful Post:
x808drifter (03-26-2022)
Old 03-25-2022, 02:18 PM   #3
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
https://www.ft86club.com/forums/showthread.php?t=62769
Granted, I'd prefer to get jack stands. But, here is a reference on the forums. Not my post nor my recommendation, so try at your own risk and all that.
SpectreRT is offline   Reply With Quote
Old 03-25-2022, 05:45 PM   #4
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
I use the pinch weld toward the rear of the car, but as far forward before hitting the plastic side skirt. The spot is just about even with the door handles. Id like to lift it a little more forward but plastics in the way.
MacSpeed is offline   Reply With Quote
Old 03-28-2022, 04:04 PM   #5
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I use the pinch weld near the front of the car to change tires on each side. If you want to do other work like side to side tire rotation or exhaust or whatever, use the front/rear jacking points.
Old 03-29-2022, 06:16 PM   #6
pope
has a funny hat
Drives: 2014 BRZ Limited
use four jack stands.
jack up the rear via the diff.
put two stands under rear-side jack points.
jack up the front via the crossmember.
put the other two stands under the front-side jack points.
rotate wheels.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
x808drifter (03-29-2022)
Old 03-29-2022, 07:05 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
Interesting. I always jack the front first, this way I can have the handbrake to keep the car from rolling. I've never trusted chocks alone (especially when lifting high in one go).
Also I think that once one end is lifted there front has less clearance than the rear, so lifting the front first makes it easier to jack the rear (vs. lifting the rear first and then not having access to the front jacking point).
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
DocWalt (03-29-2022), joemysterio (03-29-2022), slimfit (03-30-2022), Wally86 (03-30-2022)
Old 03-30-2022, 03:04 AM   #8
pope
has a funny hat
I originally wrote it as front first for the anti-rolling benefit, but then i changed it because I remembered it’s impossible to get my jack under the rear after the front is in the air.
Jacking the car from one side Jstyle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-19-2021 01:53 AM
Lifting the thing Qwimby1 Scion FR-S / Toyota 86 GT86 General Forum 6 01-29-2018 11:20 PM
axleback install without lifting car 2much Engine, Exhaust, Transmission 32 03-01-2015 01:36 PM
Possible to reach fumoto without lifting? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-23-2014 05:36 PM
DIY Rubber dash lifting fix 1Cor10:23 DIY (Do-It-Yourself) Guides 7 09-03-2014 04:59 PM
