Drives: 14 FRS Monogram, 05 Mazdasped Miata
Lifting the thing
I didn't see any sub forums that looked right for this, so decided to put it here. I just got a '14 Monogram Edition. Haven't had time to look around under it. My question is....is there a way to lift one entire side with a floor jack to rotate tires and stuff?
The manual shows a cross member in front and the differential in back for lifting the ends. Flyin Miata makes a gizmo that goes over the pinch weld so you can lift one entire side of a Miata. Wonder if anything like that exists for this car, or if there's another way. |
#2 | |
HOWEVER! I would NOT do that! I would suggest you jack up one corner at a time and place a stand under each corner before you remove the wheels. (oh, I hope someone doesn't give you a Darwin award ...... )humfrz |
Not a troll
| The Following 5 Users Say Thank You to Cole For This Useful Post: | bkharmony (01-29-2018), Leonardo (01-28-2018), MasonL1997 (01-30-2018), Rakshaa (02-01-2018), Spuds (01-28-2018) |
Drives: 2017 BRZ
There's another thread where this was being discussed recently you can take a look at:
http://www.ft86club.com/forums/showt...14#post2985714 |
| The Following User Says Thank You to Brink For This Useful Post: | Spuds (01-28-2018) |
The Dictater
Drives: '13 Red Scion FRS
http://www.ft86club.com/forums/showthread.php?t=10111
I personally leave the parking brake off and just use chocks. When I leave it on, the jack stands in front try to tip forward. Edit: Doh! Brinks link is to the same thread... |
#6 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
| The Following 3 Users Say Thank You to BirdTRD For This Useful Post: |
Drives: FRS 2013
If you want to rotate your tires with just one jack you can use the spare tire as a buffer
ex. Lift LF corner, remove LF tire, put on spare, lower Lift LR corner, remove LR tire, put on LF tire, lower Lift LF corner, remove spare, put on LR tire, lower Then repeat on the right side |
| New way to address dash lifting | toast | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 06-07-2023 12:27 AM |
| axleback install without lifting car | 2much | Engine, Exhaust, Transmission | 32 | 03-01-2015 12:36 PM |
| Possible to reach fumoto without lifting? | 1Cor10:23 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-23-2014 04:36 PM |
| DIY Rubber dash lifting fix | 1Cor10:23 | DIY (Do-It-Yourself) Guides | 7 | 09-03-2014 03:59 PM |
| Hood/Bonnet Lifting At Speed | Kefuddle | Issues | Warranty | Recalls / TSB | 14 | 06-14-2013 05:44 AM |
