Old 02-26-2015, 07:16 PM   #1
2much
I wanna go fast
Drives: 2013 FR-S 6MT
axleback install without lifting car
I searched but could not find a direct answer to this question.
Just curious if the OEM axle back can be removed from the car without jacking or lifting the rear?
Thanks
2much is offline   Reply With Quote
Old 02-26-2015, 07:41 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yes. no problem. i installed and uninstalled my axle back 3 times on ground
Old 02-26-2015, 07:47 PM   #3
sirsol66
Drives: 2013 FRS- Hot Lava
First time is not fun since the muffler is a bit of a pain to get off. The bolts are OK to reach, but getting the actual muffler off the hangers is not the easiest. Use WD40 or something on the hangers.
sirsol66 is offline   Reply With Quote
Old 02-26-2015, 07:52 PM   #4
2much
I wanna go fast
thanks guys. I have a nameless muffled track pipe, which I was assuming would be easier to install than the uninstall of OEM. Glad to know I can do this by myself without going out to pick up a jack.
Old 02-26-2015, 08:13 PM   #5
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
That Nameless muffled track pipe is a breeze. Took me about 15 minutes total, 10 of which were from trying to remove the old OEM muffler.
Congrats on the exhaust, it sounds amazing!
Churg is offline   Reply With Quote
Old 02-26-2015, 09:05 PM   #6
2much
I wanna go fast
thanks! I'm looking forward to using it, however I am definitely concerned it will be too loud for me and my daily driver. Just with OFH most people tell me the car is too loud if I'm trying to talk over bluetooth.
Old 02-26-2015, 09:26 PM   #7
tyrantcf
Drives: '16 WRX, CBR1000RR
I drove my car onto two 2x4 blocks to give myself a little extra room, its definitely doable like this but, you might want a friend to help out though.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 02-26-2015, 10:29 PM   #8
zc06_kisstherain
Drives: SWP BRZ
like sirsol66 said, use wd40 to get hangers off.
Old 02-27-2015, 07:28 AM   #9
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Easy to do from the ground. If you have an extra $20, owning an exhaust hanger removal tool will save you frustration.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 02-27-2015, 08:38 AM   #10
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
Full stock intake to exhaust people can't hear me over Bluetooth.
Annahra is offline   Reply With Quote
Old 02-27-2015, 08:43 AM   #11
OkieSnuffBox
Drives: '23 BRZ Limited
The time you save not jacking up the rear of the car will likely be offset by the extra time spent to remove the muffler with less operating room.
If you don't have a jack/jackstands, you should pick some up anyway.
Old 02-27-2015, 09:00 AM   #12
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Ah glad that this thread came up. Was planning to swap out the stock muffler with a track pipe for more volume at the track preferably without a jack.
Can't hear the my own engine with all the loud ones going past lmao
Brzerker is offline   Reply With Quote
Old 02-27-2015, 09:07 AM   #13
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Track pipe and OFH is not the way to go if you're concerned with loudness.
It's gonna be loud as hell.
Old 02-27-2015, 10:20 AM   #14
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Yes! Best money I have ever spent (it was $17 when I got mine):
[ame="http://www.amazon.com/Lisle-38350-Exhaust-Removal-Pliers/dp/B0012S9A5U"]Amazon.com: Lisle 38350 Exhaust Removal Pliers: Automotive[/ame]
I did my Berk single delete in my parking spot in front of my apartment in about ten minutes. Hardest part was torqueing the bolts back up because my torque wrench is huge.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Quietest 2.5" axleback or midpipe+axleback for my JDL UEL? stockysnail Engine, Exhaust, Transmission 22 03-28-2015 01:52 PM
Possible to reach fumoto without lifting? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-23-2014 04:36 PM
DIY Rubber dash lifting fix 1Cor10:23 DIY (Do-It-Yourself) Guides 7 09-03-2014 03:59 PM
Hood/Bonnet Lifting At Speed Kefuddle Issues | Warranty | Recalls / TSB 14 06-14-2013 05:44 AM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 09:36 PM
