Old 11-21-2014, 01:13 PM   #1
1Cor10:23
1Cor10:23's Avatar
Possible to reach fumoto without lifting?
Hi there,
I'm wondering if anyone has tried to do an oil change with a fumoto valve without lifting the front of their car on stock suspension? Might be a bit odd to try and release the lever and have an oil pan under there as well.
If anyone has any experience, please share
Old 11-21-2014, 03:06 PM   #2
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
Depends on ur oil pan height. But I do it , only diff is that i drive my fronts onto a 2x6 to get a little more room. Also it's easier to pull the pan out after
umpadupa is offline   Reply With Quote
Old 11-21-2014, 03:11 PM   #3
Foobar
SLO NO MO
Foobar's Avatar
Stock height here but I have an aero kit, so I drive it up on my ramps. I suppose I could do it in a pinch but I don't want to spill oil everywhere.
Old 11-21-2014, 03:54 PM   #4
jvincent
jvincent's Avatar
I haven't tried it myself yet, since an oil change is usually accompanied by a brake pad swap for the track, but it would be a tight squeeze for me since my oil pan is pretty high.
I will probably try the 2x6 thing when I do my next change since I won't be changing brake pads then.
Old 11-21-2014, 11:13 PM   #5
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
Not possible, jack the front end up, use some jack stands and make it easy on yourself. I have a fumoto quick valve and I always jack up the front end before I change the oil.
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 11-22-2014, 03:00 PM   #6
1Cor10:23
1Cor10:23's Avatar
To update everyone - I successfully did a full oil change without lifting my vehicle yesterday (in my condo, no less). I Lied on my back and reached in with my left hand - note, was not able to reach while lying on my chest. I have a fairly flat oil tray that I compressed further (somewhat pliable plastic) and was able to squeeze it under the car.
Old 11-22-2014, 03:41 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
I love this. Thanks!
Old 11-22-2014, 03:53 PM   #8
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
So its not necessary to lift the rear?
Carlitoz3 is offline   Reply With Quote
Old 11-23-2014, 01:08 PM   #9
Vukodlac
Vukodlac's Avatar
Whatever makes it easy for ya
-2013 Scion FR-S-
K&N drop in.
Old 11-23-2014, 04:36 PM   #10
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Of course whenever lifting car and using jack place jack stands under jack points. "Just in case"
DIY Rubber dash lifting fix 1Cor10:23 DIY (Do-It-Yourself) Guides 7 09-03-2014 03:59 PM
Hood/Bonnet Lifting At Speed Kefuddle Issues | Warranty | Recalls / TSB 14 06-14-2013 05:44 AM
protecting the pinch weld lifting points midnitz Scion FR-S / Toyota 86 GT86 General Forum 1 02-08-2013 09:36 PM
First to reach 1,000 miles? dietz Scion FR-S / Toyota 86 GT86 General Forum 22 05-31-2012 11:43 AM
