#99 |
Drives: '22 BRZ
Right, if anything this change would be a potential negative since now the shock is further from the wheel and would have less control over the wheel.
Rules are what they are for a reason though, I'm not taking that protest bait.
| The Following 2 Users Say Thank You to DocWalt For This Useful Post: | strat61caster (01-13-2022), timurrrr (01-20-2022) |
#100 | |
Drives: 2017 BRZ series.yellow
#101 |
Drives: Black BRZ - STX
FWIW, the charcoal filter thing will be put out for re-wording, who knows what is going to happen at the SEB level since emissions is involved.
The LCA had no support for a change. This is a really old battle going back to Civics/Del Sols/Integras. I couldn't agree more about it being in idgaf land. Personally, I wouldn't buy new arms. But remember, protest committee has already thrown someone out for the SPC ball joint arms, so not a lot of hope that they'd pass me if I was protested. Maybe we should stop measuring these things and people would go back to not caring. I know I never measured the pitches on my gen1 aftermarket arms, I have no clue if they are legal.
Todd K. | Ohio | STX 16' BRZ | 330F/500R | Perrin 22mm front, Karcepts rear
#102 | |
Drives: 2022 BRZ, Red
Assuming that the subframe is the source of the increased rear track width and that the arms where measured to be the same length from subframe bushing to knuckle hole (Thanks CSG Mike - https://www.ft86club.com/forums/show...7&postcount=57), then the strut attachment probably shifted to keep the rear motion ratio from getting to out of wack. Nonetheless, I see the issue now. I was coming at it from an overall arm length perspective and was confused as to how that would be illegal. Sounds like if you want to run additional rear camber, then adjustable RUCA's would be the only solution early on since that part carried over from the last gen. Last edited by Brock H.; 01-16-2022 at 02:00 PM. |
| The Following User Says Thank You to Brock H. For This Useful Post: | strat61caster (01-15-2022) |
#103 |
Drives: '13 FRS - STX
I forgot RUCA adjustable balljoints were available, that would be the way to go for legality in the short term.
#104 |
Drives: 2022 BRZ
Wonder if upper ball joints being the answer will help with the tire rub on the fender then since it’ll suck the top of the tire in more.
| The Following User Says Thank You to MacSpeed For This Useful Post: | Simmons (01-15-2022) |
#105 | |
#106 |
Drives: '22 BRZ
2022's have bad rubbing issues in the rear because of the wider track
| The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#107 |
Gotta trade in those +35s I guess? Plenty of +45s available.
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Aroundomaha (01-17-2022), DocWalt (01-16-2022) |
#108 |
Custom User Title
Got a link to the specific ones you're referring to please?
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#109 |
I misspoke, it’s not a ball joint it’s a set of eccentric bushings in the a arm like a Miata.
https://www.whiteline.com.au/product..._number=KCA326 You could also do an aftermarket upper control arm like this one; https://racerxfabrication.com/frs-br...r-control-arms Given that the rear falls naturally close to them desired camber the whiteline kit should be plenty, if it is a pain in the ass to adjust. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Locust (01-19-2022) |
#110 | |
| The Following 2 Users Say Thank You to Brock H. For This Useful Post: | DocWalt (01-18-2022), strat61caster (01-18-2022) |
#111 |
Drives: 2022 GR86
Can someone measure precisely (±1 mm) the distance between holes on gen.2 stock RLCAs?
My measurements of the Verus RLCAs: Knuckle bolt/Strut bolt 104mm Knuckle bolt/ARB end link bolt 189mm I should be able to measure the same for a stock gen.1 RLCA in the next few weeks if needed. Below are photos taken with the iPhone 13 Pro 3x zoom (to minimize perspective distortions) for the reference. Note that the numbers above were checked visually, not just by looking at these photos (that still have some distortions of the perspective). ![]()
#112 |
Drives: 22 BRZ limited
I get ~94 for the first, and ~189 for the second.
| The Following User Says Thank You to dragoontwo For This Useful Post: | timurrrr (01-19-2022) |
| SCCA AutoX Classing... | Roadcone | Tracking / Autocross / HPDE / Drifting | 13 | 10-21-2014 05:02 PM |
| Carbon fiber hood & SCCA classing | TimR | Tracking / Autocross / HPDE / Drifting | 21 | 06-17-2014 12:27 PM |
| AutoX and classing | chappys4life | Tracking / Autocross / HPDE / Drifting | 16 | 02-20-2013 03:38 PM |
| Autocross next wknd for me! Interesting response re: classing.. | MarkRacerX | Tracking / Autocross / HPDE / Drifting | 42 | 06-18-2012 01:52 AM |
